Question about Hayden-Harnett 1993-1996 Ford Probe Engine Cooling Fan Hayden 93-96 Ford Engine Cooling Fan 1994 1995
My 95 ford Probe has automatic transmission where do I fill it at??
Why does dipstick still show full after I removed oil pan and Drain Plug??
  • 36 Answers
Are you sure you are checking the right dipstick?
Posted on Apr 13, 2014
Where is the transmission oil pan located on a 95 ford probe??
it fills through the dipstick tube, with engine running,
Apr 13, 2014 | 1995 Ford Probe
Where do I add Transmission fluid on a 95 ford Probe??
So you know, I am not insulting you. I don't know what you know or what you don't know. From your symptoms, I'm confused. If you pulled the trani pan down and the trani dip-stick still read "Full", you pulled the wrong dip-stick. Your transmission takes Mercon and you will need a narrow funnel that will fit inside the trani dip-stick tube. Follow the dip-stick tube all the way to the bottom and verify that it goes to the transmission. When you pulled the trani pan down you should have four or more quarts empty into your drain-pan. Until you can confirm that the the trani is properly filled, don't continue to use the car. Running the engine while the trani is empty can damage internal componants. If you have any questions, please write back, good luck.
Need to put new gasket on transmission pan,to stop leak.95 ford-crown vic-overdrive 4 speed,automatic tranny
Jack up the car on a level surface, put jack stands and tire chocks in place. Drain transmission fluid, this usually involves loosening the tranny pan bolts on one side and letting it drain, some vehicles come with a plug like the oil pan. Once the fluid is drained, remove all of the bolts from the transmission pan. Make sure you remove ALL of the old gasket material from both surfaces with a scraper. You can clean out the pan with a commercial cleaner or just use a little gasoline on a rag and wipe the entire pan and gasket surface. Take off the old tranny filter and replace with a new one. there should be a small magnet sitting on the pan wipe it down also. Place new gasket onto lip of pan ,you may also use some sealant if leakage is an ongoing problem, then re bolt to the transmission. DO NOT OVER TIGHTEN BOLTS!!!!! Refill transmission fluid at the dipstick and DO NOT OVERFILL !!!! CHECK FLUID LEVEL
Aug 27, 2013 | Transmission & Drivetrain for Ford Transit...
Cant find where to put transmission fluid in 2000 mitsubishi monterro sport 4x4 automatic
Take a look at the transmission oil pan. If you see two drain plugs than you have the trans without the dipstick. One of the plugs is actually the drain plug. The other one is the fill plug. More often than not When you go to remove the fill plug the nut on the inside of the pan breaks free from the pan casing the plug to just turn. The norm is to have to replace the pan anytime a service or fill is needed. If you have the trans with a dipstick than you can add the fluid through the dipstick tub with a small funnel.
Jun 10, 2011 | 2000 Mitsubishi Montero Sport
How to check transmission fluid level
Most 1995-on VW models don't have a transmission fluid dipstick for checking the transmission fluid level. To fill and check the level of the VW automatic transmission fluid you have to remove a plug on the side or bottom (location depends on model and if you have an automatic vs. manual transmission) of the transmission drain pan. The factory manual refers the expensive VAG 1924 special tool for pumping the VW automatic transmission fluid into the oil pan.
Mar 02, 2011 | 2002 Volkswagen Jetta TDI
How to Change transmission fluid on 2001 celica
Hi there, hope these few steps help:
  • Raise the car with a jack and support the vehicle with jack stands sufficiently rated to safely support the weight of the vehicle.
  • Place a large drip pan under the transmission.
  • Remove the transmission fluid drain bolt with a wrench. The drain bolt is located at the bottom of the transmission facing the pan. The pan is the large flat plate that covers the very bottom of the transmission.
  • Drain the transmission fluid into the drip pan.
  • Reinstall the transmission fluid drain bolt with the same wrench used to remove the bolt.
  • Lower the vehicle to the ground after removing the jack stands.
  • Open the hood and remove the transmission dipstick from the filler tube by pulling the dipstick. The end of the dipstick will be curved into a circle to allow a finger to slide into the circle to withdraw the dipstick.
  • Place a funnel into the dipstick tube and fill the transmission with new fluid by pouring the fluid into the dipstick tube.
  • Remove the funnel and check the fluid level with the dipstick until the fluid reaches the "Full" mark on the tip of the dipstick.
  • Start and allow the engine to run for a few minutes.
  • Move the transmission gear selector through all of the gears while depressing the brake pedal.
  • Turn the engine off and check the fluid level on the dipstick. Add transmission fluid if necessary.
Best of luck.
Jan 11, 2011 | 2001 Toyota Celica
How do i check tranmision fluid on a 2004 ford exployer xlt. It has no dipstick to check level or to add fluid.
On transmission pan drain plug will have a small hex screw in the center of drain plug, with engine running and in park remove little center screw, if fluid comes out, transmission level is good, of no fluid come out, will have to pump fluid in that same little plug hole, till fluid starts to come out.
Aug 05, 2010 | 2004 Ford Explorer
How do you add transmission fluid to a 2000 town country
The tranny fluid is added through the tranny dipstick (make sure it's not the oil dipstick). Fluid color should be red and the dipstick should have instructions on how to check level (car in park, engine at idle). Funnels are your friend here.
Jul 26, 2010 | 2000 Chrysler Town & Country
Need to know placement of transmission pan, automatic, filter in or out?
Trans pan is going to be the very lowest part of your transmission. The filter swap is just slightly concerning. Not to be rude, but you might want to have an assistant that is familiar with trans basics to walk you thru the first one if locating the pan was difficult.
If you feel that the filter swap is something you would like to do, start out by getting the filter kit and reviewing the included instructions. If they are not able to give a full and detailed explanation, they sometimes include a number to call. Dont bother. Just come back here and ask!
Automatic transmissions do not come with a drain plug. You will need to loosen all the small bolts around the edge except for one, to keep the entire pan from crashing to the ground and splashing oil everywhere. pull the edge down and into the drain pan goes the trans fluid. The filter is right under the pan. Cant miss it.
It is real important to be as clean as possible. No contaminants in the trans. If you can, pressure wash the area first and stay operating room clean!
Good Luck to ya
Apr 29, 2009 | 1995 Ford Probe
Transmission fluid change
More than likely, like most automatic transmissions, yours does not have an oil plug. You need to drop the transmission oil pan to drain the old oil... You need to buy a transmission filter/pan gasket kit. The filter is located on the bottom of the tranny. You will see it when you remove the pan. Replace the filter, thoroughly remove any traces of old gasket material, clean the mating surfaces, and reinstall the pan with the new gasket. Torque the pan bolts to the manufacturers spec (you should be able to get this where you buy the filter/gasket kit). Refill the transmission through the dipstick (Capacity for the Voyager is 4 quarts, make sure to use ATF Plus (Type 7176) for your particular tranny, NOT Dexron, Mercon, or generic automatic transmission fluid, Chrysler transmissions do not like any other kind and tend to fail quite quickly with the wrong fluid). Fill to the full cold level. Start the engine, move the shifter through all gear ranges, and put it back in park. Leave the engine running and refill to cold full. Drive the car for 5-10 minutes and, with the engine still running and the car in park, fill to Hot full. You should be ready to go!
Aug 26, 2008 | 1997 Chrysler Town & Country
Hayden-Harnett 1993-1996 Ford Probe Engine Cooling Fan Hayden 93-96 Ford Engine Cooling Fan 1994 1995 Logo
59 people viewed this question
Top Hayden-Harnett Computers & Internet Experts
ray gallant
RSole
Are you a Hayden-Harnett Computer and Internet Expert? Answer questions, earn points and help others
