Question about Cub Cadet Garden
Cub cadet 2146 turns over but won't start
First time starting this season. I have fuel flow, and spark.Engine floods
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
wadembly
  • 475 Answers
SOURCE: Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Posted on Jun 28, 2009
97F350diesel
  • 1326 Answers
SOURCE: what do I do if my cub cadet 1862 has no spark?
Try replacing the spark plug first, if still no spark, sounds like the ignition coil is going/bad.
Posted on Aug 06, 2009
MNfisherman
  • 11896 Answers
SOURCE: Cub Cadet zero turn:Engine starts and runs about 5
You may have a faulty voltage regualtor that is blowing fuse. Have you tried a fuse that is 5 more amps?
Posted on Aug 24, 2009
Have a Cub Cadet Lt 1050 when you start it, continues to turn over and not start.
Check your oil. Most cub cadets use a kohler engine which will allow gasoline to drain into the crankcase and fill it with gas. The fuel must be shut off on kohlers which can cause unwanted flooding due to a stuck float. You may be surprised when you open the oil check and find gasoline coming out. If not, lightly sand the magneto and the flywheel to make sure you have a spark. If you do have a spark, it is most likely a gasoline issue caused by the flow being stuck in the bowl of the carburetor, causing a Kohler not to start
Sep 02, 2016 | Cub Cadet Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
My cub cadet 2146 tractor wont stay running and is spitting gas out of the carbrator
the new fuel we now have damages the needle and seat in the carb replace them both change the oil and add a fuel shut off valve inline with the fuel line and shut it off when not in use
Jul 31, 2012 | Garden
After a period time, my cub cadet push mover won't start.
I would be a spark tester on first,see if your getting spark,mabey bad coil or wire. If your getting spark I would have the carb checked out.
Aug 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
62 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
