Question about Frigidaire FFGF3023LM 30" Freestanding Gas Range - Silver Mist
Smell Propane I purchased my home about 6 months ago and there is a frigidaire FFGF3023LM in the kitchen. I recently started smelling propane from the stove, so I redid all the connections from the tank to the stove, and tested them and none are leaking. I still smell propane though. All the burners light and the oven and broiler work as well. Where else can the gas be leaking from if everything seems to work fine?
    Sergeant:
  • 231 Answers
I have the same issue when the tank starts to get low and nearing the time too refill. Just thought I would share that in case that is the issue. I also redid all my connections the first time it happened.
Posted on Apr 13, 2014
jumptrout51
  • 3361 Answers
SOURCE: Oven won't turn on, but the stove is fine!
Replace the oven glow bar ignitor.
Posted on Apr 20, 2009
  • 99 Answers
SOURCE: Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
Posted on Aug 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: Oven wont lite ?
How them oven Ignitors work
Posted on Sep 21, 2009
  • 1891 Answers
SOURCE: frigidair gallery old stove/oven gass, when I put
replace oven ignitor .
Posted on Nov 20, 2009
  • 1531 Answers
SOURCE: I bought gas cook stove
There is a regulator behind the bottom drawer remove the drawer.look in the back you will see a silver box that the oven fuel rail is on just below the rail there is a brass fitting that needs to be turned clockwise till it stops it can be hard to turn some times but turn it till there is no clearance between the nut part of the valve and the silver box then you can start your oven and it should work fine you can also adjust it to get a little more flame if needed.
Posted on Feb 03, 2011
Smell of propane
call the company back explain to them about the smell and where you smell it and would like another test of the lines and appliances that are hooked up as to your medical seek a doctor
Apr 19, 2017 | Heating & Cooling
Smell propane after I ran out and filled it back up> I replaced the regulator behind the stove but still smell propane
It is not uncommon to "smell" propane when you run out. Propane has an odorant called mecapitan added to it so you may detect it. When you get low or run out the mercapitan is typically in greater volume than the gas itself. Once you refill, you will also smell it temporarily. Check all connections for tightness and leaks, use a leak solution, and if all is well, start it up and monitor it. The odor should dissipate. If it does not, contact your local licensed propane technician.
Jan 16, 2014 | Tappan Kitchen Ranges
I have a frigidaire gallery propane stove. I just bought it a couple weeks ago. We converted in from natural gas to propane, the top works great but the ovens gives off a terrible smell whenever we use it....
THAT IS VERY COMMON,YOU HAVE TO EITHER CHANGE THE ORFFICE ON THE OVEN AS WELL OR ADJUSTED,TURN IT DOWN CLOCK WISE TO REDUCE THE GAS FLOW,THEN OPEN THE AIR FLOW WINDOW ALL THE WAY,ADJUST 1/2 A TURN AT THE TIME .....AND PRESTO
Apr 21, 2013 | Kitchen Ranges
Oven will not start and smell propane
You ignitor although it is glowing it is not pulling enough amps to open the safety valve. It must draw at least 3.5 amps to open the safety valve.
Jul 22, 2012 | GE JGBS07PEAWW Gas Kitchen Range
I have a Goodman gas (propane) pack heat pump which was installed a month ago on our new home. There is a horrible smell coming from around the unit, and some soot is on the propane pipe just in front of...
Please SHUT IT DOWN !!!!!!!!! Contact the installer because the LP propane conversion kit has probbaly NOT been installed.Any gas system should NEVER make any soot.
Oct 31, 2011 | Goodman GMS90703BXA Heater
I have a ge Profile propane range.at times I get a smell of propane near the range.we checked the connections at the back of the stove & they seem to be fine.the smell seems to be stronger at times as...
Open up the range top and check the piping connections right up to each burner. Use soapy water and a small brush to do this safely. Chances are you have a leak. J.
Jul 05, 2010 | Maytag MGR5770 Gas Kitchen Range
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
GE XL44 Working fine but awful burnt propane smell
Remove the burners and clean them with EASY OFF oven cleaner. The passages are likely plugged and this causes incomplete burning of the gas. If you do smell raw gas shut the gas to the stove off RIGHT AWAY and call the local gas supplier.
May 12, 2017 | Kitchen Ranges
Frigidaire FFGF3023LM 30" Freestanding Gas Range - Silver Mist Logo
90 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
