Question about Refrigerators
Ge gss25jfmcww since a replacement motherboard was installed it has had problems with defrost cycle. Burned out 2 defrost heaters. Ice in the ice bin gets melted into a clump. Food gets freezer burn
With the new motherboard, the fan does not turn off when the freezer door is opened. The ice dispenser auger motor frosts up and seizes when the freezer gets cold again.
  • 283 Answers
Taking these one at a time: It's highly unlikely the MB took out heaters. If indeed they "burned out", I'd check for failed heater safety thermostat which is equally unlikely as the mainboard to have caused the failure.
Far as ice clumping in the bin, you'd need to run a 24 hour recording thermometer test to find possible spikes in freezer air temperature. Also check or replace the evaporator thermistor. On freezer burn, that comes from improper (non-airtight) wrapping of food.
Posted on Apr 13, 2014
  • 298 Answers
SOURCE: Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Posted on Nov 27, 2007
melnavz
  • 1226 Answers
SOURCE: Ge Ice Maker Gs25sgmcbs
Hello!
There is a problem in the water dispenser outlet of the freezer, in this case i will suggest call service tech of the freezer and the ice maker so that the system will be personally diagnosed thoroughly to resolved the existing problems.
Service center in your area maybe available and not then the vendor is the right person to contact.
best reagards, melnavz
Posted on Mar 04, 2008
  • 54 Answers
SOURCE: GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
Posted on Jul 03, 2008
  • 143 Answers
SOURCE: my daughter left the freezer door open overnight.
YES.
Posted on Aug 13, 2009
SOURCE: Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Posted on Aug 26, 2009
Why does the defrost cycle melt ice in ice maker bin and drips water down on food?
Check the door seals for tearing, it will cause an extended defrost cycle do to high humidity.
Jul 10, 2015 | GE Refrigerators
Defrost ge regrigerator
The most common problem with the defrost system is a burned out defrost heater. It is located behind the frz back wall usually attached at the bottom of the aluminum cooling coils which will probably be full of ice and frost buildup. You will need to melt all the ice off the coils with something like a hair dryer. The heater is inside a glass tube and can be tested with a multimeter or sometimes you can see the break in it through the glass. In some cases there are 2 or 3 heaters at different levels. Replacement kits should include as many as needed for your model. Replace them all. 2 other parts to the defrost system are the defrost timer (usually located on the front channel under the freezer door) or the termination thermostat which is a silver disk clipped to the top of the aluminum cooling coils with 2 wires going to it. Any of those 3 parts could cause the frost buildup but the heater is the most common.
Apr 05, 2015 | GE Refrigerators
Ge side by side.. freezer randomly defrost's. gets warm enough to melt all the ice in the ice bin.. there is a lovely ice sculpture in the fridge now as it refroze when dripping out. is there a way...
The only thing you could do is replace the defrost thermostat...its the part that determines when the defrost heater cuts off....typically it cuts off the heater around 40 degrees (the defost system is comprised of only 3 parts..the heater..the control....and the thermostat)
GENE
Sep 15, 2011 | GE Refrigerators
DEFROST CYCLE IN FREEZER NOT WORKING PROPERLY BUILD UP OF ICE ON THE OUTSIDE/INSIDE OF ICE DESPENSER
1. Check defrost timer. 2. Check defrost thermostat. 3. Check defrost heater. One of this are more than one may be defective replace.
First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it. Thanks and hope helpful
Jan 29, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Nov 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Eterna series Ess23xgsbb That the ice maker makes and but the despinser keepe freezing over. We have taken it out and defrosted it and with in 48 hours it frozen over again
I assume you're talking about the ice dispenser and the ice bin being frozen over.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and causing the water to spill into the ice bin. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator GSS25JFMCWW not dispensing ice but dispense water
I have the same problem with the same unit. I removed the ice tray and held the open door cut-off switch closed. I then pressed the lever to dispense ice. I hear a humm like power is getting to the motor but the motor is not turning. I hear a click like the selonid is engaging. I'm having to assume at this point it's the motor and I am going to go ahead and order a motor. I've found a motor for the unit at partselect.com for $65.54. Hope this helps you.
Apr 21, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Water not draining from ice bin and ice forming on grid but not releasing into bin
Dear customer,
if u are refering to a problem in your freezer then please check the following..
this should solve the problem.. thank you..
Jul 15, 2008 | GE Refrigerators
Ge freezer problems
check the defrost heater it could be bad if it is good change the sensor on the top of the evaperator coil it is white and about 1 inch long, has white wires connected to it
May 06, 2008 | Refrigerators
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
