Question about Samsung DVD-VR375 DVD Recorder/VCR
DVD-VR375 Disc Tray Won't Open
The tray on the dvd side wont open and when I press the the disc eject button on the player it sounds like it just sits and cycles
    Top Expert:
  • Samsung Master
  • 43,014 Answers
The disc ejection mechanism may have failed.
Posted on Apr 13, 2014
4 Suggested Answers
virtualhost
  • 2185 Answers
SOURCE: WHEN I PRESS THE OPEN/CLOSE BUTTON THE DISC TRAY
Look for the small hole in your dvd rom. This hole usually can fit a paper clip. Push and hold the paperclip inside the hole to open the dvd tray.
Posted on Dec 28, 2009
quang123
  • 107 Answers
SOURCE: Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
Posted on Dec 09, 2008
SD Tech
  • 14553 Answers
SOURCE: tray wont eject on samsung dvd-Vr375 vcr dvd combo
someone has to open the unit to see if something (a disc or something else) is jammed--mechanism could be jammed or out of alignment.
Often if the disc is jammed it can gently be moved to let the unit work again.
Posted on May 30, 2012
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
Tray wont eject on samsung dvd-Vr375 vcr dvd combo
May 30, 2012 | Samsung Televison & Video
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
The DVD Player won't Open/Close and there is a DVD inside. How do I force it open?
The DVD player jammed, that is why it is not opening.
To get it to open and close, you will have to unplug the player, then unscrew the screws around it. Take off the cover then you will have access to the disc tray. Then you can plug the player and press open, it will attempt to open but stop, then you can try to apply a little force in pushing the disc tray towards the open direction, it will sit properly and open up.
You can as well unscrew the disc tray and remove your disc, then you press the open button and sit the disc tray properly it will open freely and easily after then.
Take care and good luck
Oct 30, 2010 | Mitsubishi DD-4020 DVD Player
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
The dvd player tray does not open
# Ensure that any locking feature on the DVD player is disabled.
# Attempt to open the disc tray.
# If the issue is not resolved, turn off the DVD player.
# Unplug the power cord from the electrical outlet for 10 minutes.
# Plug the power cord back into a functional wall outlet.
# If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
good luck!!!!!!!!!!!
Sep 20, 2009 | Toshiba DVD Player
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Samsung DVD-VR375 DVD Recorder/VCR Logo
448 people viewed this question
Jerry Greenberg
Jerry Greenberg
