Question about Sharp Camcorder Battery for VL-E39U
Battery will not charge
Purchased new charger the new and old charger will not charge battery
    Top Expert:
  • Sharp Master
  • 43,979 Answers
The battery may be no good.
Posted on Apr 13, 2014
    Problem Solver:
  • 26 Answers
Dear Lisa
Check may be that battery is faulty ,
or new charge is not compatible with the model
Cheers
Power-pack not charging battery
bad connector on pc or received bad power/charger unit try getting new charger to verify
Aug 08, 2014 | Toshiba Satellite T215DS1150 Netbook
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
Dec 11, 2013 | Black & Decker Black and Decker 18V...
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
Packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Apr 04, 2012 | Computers & Internet
I just purchased a new battery and new charger off ebay. The battery died and now I cannot get it to charge. I am not sure if it is the battery or the charger that has the issue but the camera will not...
If its a new battery charge it overnight. If its an overseas or aftermarket charger make sure
the battery terminals line up with the battery properly. I never recommend these aftermarket
chargers because the lifespan is very short. Whats the battery type and charger type??
Jan 23, 2011 | Cameras
My battery will not charge. I purchased a new
The flashing on a charger usually means that the battery is defective or will not take a charge. I would take the battery back to the vendor and have them check it. A good indication is that if your old battery took even a small charge, it is not usually the charger that is the problem. It points to the new battery being faulty.
Jan 12, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
My c500 presario won't charge and i think it's the charger. But when my battery went dead other times and i try to turn it on the lightning bolt indicator would always blink for a few secs. But now it just...
You probaly have a broken DC JACK on the motherboard. Therefore, regardless if you have a good power adapter. The power is not making a connetion to the battery because the DC JACK throught which the power flows is broken.
Try another adapter and remove the battery. If the computer is powered up using the new adapter then the old adapter is bad and the DC JACK is good. Replace the battery and if the batter charges, you can identify the old power adapter as the culprit. If the batter does not charge but the laptop powered on. Then both the battery and the charger is faulty-battery not holding charge.
Good luck
Sep 27, 2009 | HP Compaq Presario C500t Notebook
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
Will not charge batt
I am sure you ave figured out what to do for this poblem but if not...I had this problem with a nikon I just purchased. The guy I bought it from said it was the battery charger, so I purchased a battery charger on ebay-"new nikon d1 battery charger" was the actual listing and it cost about $40.00. You can get the actuall charger that comes with it on ebay- but it cost alot more money. I recieved the product, tried it on my battery (which was suppose to be new) and it still would not charge. I took all my stuff (battery, new charger, old charger) to a local battery shop in town and they tested it all for me. Come to find out it was not the charger all along, it was the "new" battery- UGHH! The whole point to this story is this- if you have not aken your battery and charger to a battery shop yet- do that first. Then go from there. Like I said- you canget the charger on ebay- and the battery can be bought for about $36.00 too. I would not recommend buying both like I did! Good luck.
Nov 16, 2007 | Nikon D1H Set Digital Camera
Sharp Camcorder Battery for VL-E39U Logo
112 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
