Question about Pyle Car Audio & Video
Pyle PLBT74G where do you connect pink wire for back up camera, there are no instructions on this
5 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: Can you connect any version
Please check the links bellow if it helps:-
http://www.ehow.com/about_5048214_flip-camera.html
http://www.ehow.com/how_5832401_download-flip-video.html
http://www.ehow.com/how_5969609_do-flip-video-clips-website_.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 05, 2010
  • 375 Answers
SOURCE: i have a pyle 12"
I am afraid in order to make use of your sub, you will need to buy an amplifier and a cabling kit to run it. You could run it straight from the headunit from one of the main channels but it would need a crossover so it wasn't fed any sounds which it couldn't cope with (high frequencies, they require very fast movement of the speaker cone, your sub wouldn't be able to do it)
Here is a link to a downloadable copy of headunit manul.
Hope this helps
Posted on May 09, 2011
  • 45 Answers
SOURCE: how do i connect the
ON THE BACK OF THE UNIT YOU SHOULD FIND A RCA CORD WITH A LABEL ON IT THAT SAY'S CAMERA HOOK THAT VIA RCA TO THE BACK UP CAMERA YOU'LL PROBABLY NEED A 17-20 FOOT RCA. IF THERE IS NO CAMERA INPUT USE THE VIDEO AUX IN
Posted on May 27, 2011
  • 4 Answers
SOURCE: What to do with the
This particular model has two inputs, one could be used for the rear view camera, the other for a tv tuner, dvd player or better yet, a front facing camera. A blue screen Indicates that the input is inactive or has no power.
Posted on Jan 09, 2016
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
May 19, 2014 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
Music video to player screen off sd card
Try a different video player and see if that solves your problem
Feb 21, 2014 | Pyle PLBT74G Car Video Player
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
No maps on pyle plbt74g
Hi i so happen to have the sd card maps for this pyle i have the same dvd radio in my truck if your interested let me know computertech1990@gmail.com
Feb 21, 2013 | Pyle PLBT74G Car Video Player
Installation instructions for pyle view plcm7200
Where do I hook up the green wire on Pyle 7200 rear view camera
Dec 27, 2012 | Pyle PLCM7200 7'' Tft Mirror Monitor W/...
There is a black power cable with two leads for the power for the camera but I don't have in the instructions what to do with it
This is how to hook up the Pyle PLCM7300BT:
On the license plate camera, plug the black cable provided with 2-wires inside (one red and one black) to its counterpart on the camera. On the open end of this black cable, strip and connect the black wire to the car/truck metal body part.
Connect the red wire from the camera and the green wire from the monitor (part of the big black cable from the monitor) to the power wire to the back-up lamp socket.
Connect the Red wire from the monitor to a switched terminal on the fuse box so that it would only have power when you have the ignition key on.
The rest of the wiring is simple and common sense.
To operate, turn on the ignition of you car/truck and put it on reverse you should see the camera view. Put the car/truck on Park, the monitor screen should go back, if not, push the power button once.
To set up the blue tooth: Push the power button on the monitor so that you can see the blue screen and "no Input". Put your phone on discoverable mode and push scan for device. AT the same time push the "pair" button on the monitor.
I did all the figuring out on the bench using a 12 VDC power supplies and contact switches to make sure I understood how it worked. Once installed on my 1988 Suburban, it worked as expected.
The only problem I had to patch the long green wire (reverse car) so that it reached the back-up light socket.
Let me know if you still have problems. Email me at wayne.tan@wdc.com
Wayne Tan
Feb 24, 2011 | Pyle PLCM7300BT Mirror Monitor
How to watch video while driving
connect the pink wire to your ground wire this will bypass the system , it will let you watch videos at any point
Nov 25, 2010 | Pyle PLD7MU Car DVD Player
I doesn't work
gound pink wire in order to make video play
Feb 12, 2009 | Pyle PLTS76U Car DVD Player
Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Dec 30, 2008 | Pyle PLTS76U Car DVD Player
Car Audio & Video Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
