Question about Garden
Black decker problem
My Grasshog #NST2118 shaft does not rotate freely. Seems the shaft is jammed up with grass or it is rusty and needs greasing. How do I remove the housing for the spool assembly to see if the shaft is bound up with grass or if greasing/oiling is needed?
  • Dave
    Dave Apr 13, 2014
    It's my weed wacker, not a vacuum.
  • Dave
    Dave Apr 13, 2014
SOURCE: Black & Decker GL720 Strimmer not working
Hi there, I just thought I'd mention that I also have a Black & Decker GL720 with the same problem. I'm pretty sure it is less than 1 year old too, so well within the 2 year manufacturer's guarantee here in the UK. I think it may be a UK specific model and the phone number from MrFixIt looks like a US number.
I have tried taking the plastic casing apart, but with no luck, as the two halves won't come apart easily, even after removing all the screws. Ah! OK, I've found out the reason that it wouldn't come apart now, there is a screw hidden under the 123 sticker.
It's all apart now, and I see what is wrong, there is a belt running between a small cog and a large cog, and in my case the large cog has partially melted and the belt has come off. Unfortunately, I'm not sure I can get the replacement part now. Hopefully with yours, MrFixit, the belt might have just slipped off, fingers crossed.
Anyway, here is a service diagram of it in case it will help anybody, but as you will see it says only certain parts can be ordered. If anyone locates a supplier of all the parts please post it here.
Many thanks
Simon
Posted on Jun 03, 2009
SOURCE: Black & Decker Grasshog GH600 lever replacement
this has been driving me crazy. try this pdf from the black and decker site http://support.blackanddecker.com/cgi-bin/blackanddecker.cfg/php/enduser/fattach_get.php?p_sid=98uDbvBj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=1885&p_created=1148586888&p_olh=0
Posted on Jun 28, 2009
SOURCE: how to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Posted on Nov 16, 2009
  • 903 Answers
SOURCE: how to change the spool in the black and decker
Is this the cordless Grass Hog? Turn the trimmer upside down so you're looking at the bottom. There are two orange tabs on either side of the spool -- push these in and the head should pop up so you can pull it out.
On the new spool, feed the cord out several inches and stick it through the hole in the trimmer where the old cord stuck out. Then pop the spool into the cavity so that the orange cover faces out (toward you). Pull the cord taut and make sure it is not long enough to hit the plastic guard. If it is too long and it touches the guard, pull the spool off and wind the cord in a little bit. If the cord is too short, pull the spool off and thread out a little bit more length and try again.
Turn the trimmer right side up and turn it on to make sure it works. If you hear a loud rapid thumping sound that sounds sort of like a machine gun, the cord is too long and is hitting the plastic guard.
Posted on Jul 04, 2010
  • 221 Answers
SOURCE: We have the Black & Decker Grass Hog xp 7.2
You should be able to download a new manual at the following link. I hope this helps.
Normal 0 http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jul 12, 2010
How to I feed the line in my Black and Decker battery GrassHog weed eater
There are 2 models one has a extendable handle these are both Grasshogs, if i was told incorrectly please contact me. Thank you
12" 18V Cordless Trimmer and Edger MODEL # NST2118 Page 10 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90559891,NST2118.pdf
18V Cordless Trimmer and Edger MODEL # NST2018 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90509965,NST2018.pdf
Jul 09, 2011 | Black & Decker Garden
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
Battery to fit Black & Decker CST20000 Grasshog weed eater. Where can I buy just the battery or battery pack?
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
May 20, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker
You have missed a screw about half way, there is one under a sticker.
Sep 03, 2009 | Black & Decker 14" Grass Hog Xp...
Motor spins, shaft does not...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Jul 26, 2009 | Black & Decker 14" Grass Hog Xp...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
