Question about Zebra S4M Thermal Label Printer
Zebra S4M - Print quality problems - not keeping Thermal Transfer
Hi,I think that this is causing the print quality problems that we are having.When I print a PAUSE self test, the label prints out perfect. When I print out a normal label it is very faint.This is a new "2nd hand" printer which we are just setting up.I've noticed a "Ribbon In" message on the LCD screen - which would indicate that it was set to Direct Transfer, but when I check the settings it is on Thermal. However, in the past I have notice this change from Thermal Transfer, with no intervention from us
.Any ideas much appreciated.
  • nicola_swins Jun 29, 2009
    Thank you for the info, that sounds like it could be the answer. I don't have access to the driver so am awaiting support looking into this.
    The other issue that we are experiencing is the bar code printing across 3 labels, we are setting up a new application and don't currently have our label print specification mapped, so are wondering if the format in our TEST system is not correct for our labels.
    Any other advise would be much appreciated!
    Cheers,
    N
  • 31 Answers
If you are using a windows printer driver then perhaps you have "Direct Thermal" selected in the printer preferences. The driver setting will override anything you have set in the printer. So every time you send a new print job the settings get changed to what they are in the driver.
Posted on Jun 27, 2009
  • BarcodeGuru Jun 30, 2009
    It's hard to say without knowing everything about your printer setup and how you are printing. The label format being sent to the printer has to correlate to the size of label that you are using and the printhead dpi.
I am using a Zebra S4M Thermal printer with Zebra brand labels. I changed out the roll of labels with a new roll and it will not print. It completed the task like it always does but i only get a blank...
The new labels are probably not thermal labels. Test them by applying heat to the surface and see if they turn black. If they do not change, then they are thermal transfer labels and not direct thermal. Contact your label vendor and have them replaced.
Jun 09, 2011 | Zebra S4M Thermal Label Printer
Hi I am unable to print from Zebra S4M.. while printing the configuration it prints but does not print the test page or the label.
There a number of things that can cause that: 1) wrong printer driver was installed 2) cable to printer is faulty 3) wrong port was selected when the printer driver was installed
Check these and let me know!
Jan 20, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
Zebra s4m is printing blank pages
turn printer off, press pause buton, tur on, wait 5 secunds and relese the button. He goin to print the test label, Pause. check Darkness seting, ajust if necessery. don't forget to save. To go out from the test, turn printer off and on again.
the ribbon is on the correct way?
The labels are Termal Transfer and you don't have ribbon in the printer.
Jul 02, 2010 | Zebra S4M Thermal Label Printer
Printer is paused alert ribbon out, but we don't use a ribbon
Sounds like you're just in the wrong printing mode. Go into your front panel setup and search until you see
PRINT METHOD:
THERMAL TRANSFER.
Press the arrow buttons until it says DIRECT THERMAL, then save and exit.
Apr 05, 2010 | Zebra S4M Thermal Label Printer
Warning Ribbon in
If you're trying to print using Direct Thermal and you have a ribbon installed, the sensor will set off that alarm.
If you WANT to print using direct thermal, remove the ribbon.
If you want to print using ribbons change the Print Method in your front panel setup to THERMAL TRANSFER.
Mar 01, 2010 | Zebra S4M Thermal Label Printer
I cant seem to get rid of the "Ribbon In" error on my zebra S4M
1st change the print method to direct thermal on the LCD panel,  then check the driver on your computer, make sure you are printing with direct thermal
u can check the driver at printer & faxes , right click the printer and select printing preference .
Feb 11, 2010 | Zebra Z4M Printer
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Aug 19, 2009 | Zebra 203DPI Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
Oct 26, 2007 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
927 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
