Question about Nordic Track NordicTrack FreeStrider 35 S Ellipitical Trainer
Stuck on start striding - Nordic Track NordicTrack FreeStrider 35 S Ellipitical Trainer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
There is a sensor that is magnetic to count your strides. it needs adjusted or replaced. it is located near the front pulley. its normally a black cylinder with a wire coming out of it
Posted on Apr 20, 2014
Math Problem Help?
2 feet 8 inches is is 32 inches.
4,500 x 32 is 144,000 inches
divide it by 12 to to bring it back to feet. The answer is 12,000.
When working in feet, which have 12 inches, it is easier to bring to a single figure rather than using fractions. This is the benefit of the Metric system as everything is based on 10s and hundreds and thousands. Millimeters, Centimeters and Metres.
Jan 04, 2017 | Homework
How many miles does 6710 steps with a long stride
5,280 feet in a mile. Assume 3 feet for a long stride, multiply 3 x 6710 = 20130 feet. Divided by 5280 = 3.8125 miles. Adjust math for stride length if different.
Feb 10, 2015 | Cars & Trucks
How many miles are in 5101 steps
That depends on the length of your stride. If you have a very short stride (less than 12 inches), it'll be less than one mile. If you have a very long stride (36 inches or more), it'll be more than three miles.
Jul 29, 2014 | Exercise & Fitness
How does a person convert the steps to miles? How many in a mile?
Thats pretty hard to do since each persons stride is different. If you know your stride length then you can just multiply the length of your stride by the number of strides. S x N.
Oct 18, 2013 | Exercise & Fitness
Need stroller manual
Either call Kool Stop in Oregon and ask for the Kool Stride manual you need or download this online one which is similar...
http://ebookbrowse.com/kool-stop-kool-stride-sr-paramount-series-jogging-stroller-owners-manual-pdf-d359030674
Apr 10, 2012 | Baby Gear
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
How to measure your stride?
one long step or stride is about 2.2 feet
Jun 24, 2010 | Exercise & Fitness
Adjust stride length
I went online and used the Omron manual again. I had tried it before and it didn't seem to work but just persevered and had success.
Apr 06, 2010 | Omron Hj 720ITC Advanced Pocket Pedometer
Nordic Track NordicTrack FreeStrider 35 S Ellipitical Trainer Logo
146 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
