Sharp aquos problems
Foggy black cloud on screen
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 13, 2014
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
cheater21
SOURCE: Sharp Aquos 37" picture
Those lines are because of "Interlacing". a REALLY bad case of it. what are you watching when this happens?
Posted on Jan 02, 2009
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
highspeedsan
  • 61 Answers
SOURCE: sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Posted on Apr 30, 2009
  • 6 Answers
SOURCE: My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
Posted on Sep 03, 2009
Hi i have a sharp 70" lED aquos tv. But recently there is a big dark foggy spot on the center of the screen. Can you please tell me what you think the problem is? Thank you
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 11, 2014 | Sharp Aquos Televison & Video
Black cloud like fogged on Sharp Aquos 37"tv
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Looking for solution for Sharp Aquos LC32D41U 32 "
when it goes black then check with flashlight 2 in from screen and see if you see a picture, if so then inverter board is going out, you can google your model and inverter and find the replacement.
Dec 30, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
I have a sharp Aquos and the input button will not come on black
If you get sound but no picture (black screen), There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Oct 10, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Aug 28, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Tv screen keep going black,
did you check the sleep mode on the tv?
Aug 05, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp aquos vertical black line
Call Sharp at 1-800-237-4277. There are firmware upgrades that this lcd needs to resolve issues. Good luck!
Nov 15, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
** picture - solid green power light - relay clicks
yes,the set has a main video processor board bad.Sharp is well aware of this problem,and with persistence sharp will give in.
Mar 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
