The bushing that the ascend and descend plates rides on broke where can i find a replacement
SOURCE: i have a problem in sorting
If your using windows:
Open cmd.exe (program files>accessories>command prompt)
use the sort command in this syntax:
sort "path name and or file name"
you may also use file exports like this for example:
sort birthdays.txt > sorted birthdays.txt (single forward will write over old files and make new ones)
sort birthdays.txt >> sorted birthdays.txt (use double forwards to made amendments to the file)
the "/R" function will reverse the sort order, for example:
sort /R birthdays.txt
thats all, hope this helps. I cant do much else with the information given.
SOURCE: LOOKING FOR REPLACEMENT WHEEL COVER FOR MODEL 141
It's known as a tire. Do a search for bandsaw tires online and you'll turn up a variety of sources....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: jet model jwbs-14cs bandsaw purchased used, need manual
http://www.cpojettools.com/products/708115k.html
Scroll down and click the "Manuals" tab. Your free PDF awaits...
SOURCE: Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
SOURCE: where can I buy a belt for a 9 inch mastercraft
Check with eReplacementParts.com by going to the link below. http://www.ereplacementparts.com/delta-bs100-type-band-saw-parts-c-3275_3481_3509.html $13.29 for the belt, one in stock.
Check out some great ascenders on eBay.
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=climbing+ascenders&_sacat=0
