Question about Carrier 38CKC036 Air Conditioner
Blowing hot air fan not turning outside making a humming noise
I can hear that the unit is trying to start but the fan is not turning and the unit is making a humming noise and seem like it is putting off heat
  • Shannon Rush Jul 11, 2013
    It is blowing cold air like always but with a humm.
  • 25 Answers
Replace the run capacitor. It is a silver cylindrical object located in the electical compartment of you outside unit. There is most likely three places on the top where different color wires are attached. One is marked F,or Fan. The center should be marked C, or Common, and the last should be marked Herm, with wiring to the compressor. Make sure you write down or label each wire you remove and it's correct location. They must be installed on the new part just like they were on the defective part. For you to know which dual run capacitor you need, the old one will have printed on the side either 370, or 440 v,as in volts. You must also need to know the microfarad rating and it is also printed on the side with the voltage rating. Since this is most likely a dual(runs fan and compressor) you should see two ratings abbreviated as mfd. Something like a 5mfd for the fan motor and perhaps a 35 mfd for the compressor. CAUTION !!! This device has line voltage and you must insure the power is off at the disconnect/ breaker BEFORE you begin the repair. Sounds complicated but really only takes a few minutes. The main thing is getting the right mfd and voltage ratings for the new part and keeping a record of where the wires were mounted on the old one, and putting them back the same place on the new part.
Posted on Jun 18, 2009
  • 614 Answers
You have a bad fan motor of fan capacitor. Call service tech. Capacitor cost + service about 130. Fan motror depending about 250.00 Rus
3 Suggested Answers
  • 1033 Answers
SOURCE: A/C suddenly started blowing hot
Hello, sounds like a bad fan capacitor. Check out the capacitor does it look swollen or bulged?
Posted on May 31, 2011
panilling9
  • 284 Answers
SOURCE: heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
Posted on May 26, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Hello i have Carrier Weathermaker 38tkb air conditioner unit. It's about 6 years old and when i got home today, the unit itself wasn't working. Although the blower fan in the furnace inside was blowing,...
The humming noise and dimming of the lights is an indication something in the outdoor unit is locked up or has failed.
Check the capacitor as it may have gone bad. If the capacitor is good, then you either have a failed motor, a failed compressor, or both.
Jul 07, 2010 | Heating & Cooling
The fan is not turning on my outside air unit but it is still blowing hot air through the vents. There is also ice build up at the bottom of the unit. It is making a humming sound.
You will need to replace the outside fan,or condenser fan motor.
Shut unit down,before the compressor gets damaged.
Without the condensor fan the heat will not be blown to the outside air and the unit will not cool.
You may be low on freon too,have it checked.
Jan 19, 2010 | Samsung AW0603B Air Conditioner
Unit is running, but is no longer cooling. Fan is blowing, but air is not chilled (or cold). Unit has been running fine until a couple days ago. It has been turned off for the last 12 hours and tried...
not sure if it is a package system or a split but this is what you do.go outside where your outdoor machine is, after it has been shut off for awhile, and you should hear 2 distinct noises.1 is the outdoor fan, you should see it spinning.the other is a comppressor hum.some compressors have noise bags on them so listen closely thru the fan noise.if you hear no hum listen for a hum about every 2 to 5 minutes.if you hear this hum every so often, chances are you compressor is seized or stuck.the only thing to do there is get a tech and try a big boost to get it going.
Aug 07, 2009 | Fedders A6P09S2A Air Conditioner
My a/c system is blowing hot air; outside fan is not engaging
First check for line voltage 240v...if thats good .check for burnt wiring at fan capacitor.if you hear the compressor humming but still no fan you may need a fan motor.. when buying your new motor make sure to match horsepower and r.p.m
Jun 22, 2009 | Weather King 10AJA3601AH Air Conditioner
Heat pump not running
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
836 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
