Question about Acer Aspire One Netbook
Black screen of death on my acer aspire one
Will not open windows powers up and only black screen
    Top Expert:
  • Acer Master
  • 8,211 Answers
Plug in a monitor using a usb and vga cable,if it works then it could be screen gone or what they call the inverter thats gone.
Posted on Apr 05, 2015
  • 3 Answers
SOURCE: acer laptop has black screen but power light is on
Does it appear to be doing anything. Is there a flashing "_" at the top left of your screen. If not try hooking a monitor up externally and turning the laptop on.
Posted on Dec 23, 2007
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
patemi
  • 366 Answers
SOURCE: black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Posted on Dec 30, 2008
Reno7777
  • 3 Answers
SOURCE: ACER Aspire One screen black out after start up.
OK, Not sure about the Aspire One, But I had the same problem with the Aspire 5610Z.
I simply found the Bios battery and with a small screw driver, created a short circuit of the bios by touching the two leads (just for a couple seconds) from the Bios Battery to the Motherboard. And It Works Fine Now!
Be sure to Disconnect all power from the laptop, and remove the Battery before doing this.
You can do as I did and download a free manual of your laptop which shows you where the bios battery is located.
Good Luck ô¿ô
Posted on Feb 24, 2009
ailia
  • 175 Answers
SOURCE: acer aspire one black screen and no boot
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Posted on Jul 08, 2009
Screen goes black close lid and open screen works fine
what configuration of the power manager do you use? laptop goes to hibernation mode automatically or by pressing the power button or by closing the lid?
Feb 04, 2014 | Dell Inspiron 1420 Laptop
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Six years excellent service then the screen went black except during start-up the start-up screen flashed om and off, and remained black through the Windows start. The screen did flash on for a second on...
You may have failed backlight inverter circuits, caps failure in the power supply, or bad lamps. Here is the service manual: http://www.eserviceinfo.com/downloadsm/22184/SONY_SDM-HS73.html
You will need to open it up and take some voltage measurement in the power supply first to make that you do have correct DC voltage feeding the inverter PCBA.
Mar 25, 2010 | Sony SDM-HS73P 17" LCD Monitor
My dell was hit by lightning and now i cant get it to boot up
hi there;
really,lightning has a great power voltages supply,thousand of volts was supplied in one strikes of lightning.this depend how much voltage was induces on your computer,mostly your avr and psu might be damage by checking if there is power determining the fans inside avr and psu if running maybe you have the power,and some led light are blinking ,some how to be sure you can use multi tester if you have knowledge on this.basic approach if you have black out screen and good power supply,pull out ide cable of hardisk and cd room from mother board,you can run pc w/o them to check your start windows if will open run your pc if still black screen,take another video card and memory card try to replace them and rn your pc,if windows open fine if not maybe you have damage the mother board from lightning.replacing defective devices can put back your windows open.best regards
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
Black screen, unable to make it operate
How can you get a message about power problem if you can't see any words display on the screen?
Could you tell me more details please?
Mar 08, 2009 | IBM ThinkPad T30 2366 Notebook
Compter won't open windows
first try that safe mode option and do log in . when you successfully log in restart your computer . this happen mainly when there is sudden loss of power supply to the cpu. shut down your computer properly by pushing the power button on the cpu
Jun 19, 2008 | Computers & Internet
Acer Aspire One Netbook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
