Question about Whirlpool Refrigerators
Water on the whirlpool refrigerator won't work
Water won't come out
  • 571 Answers
Check the water pump.
Posted on Apr 13, 2014
Water won't stop coming out from the cold water dispenser
The cold water dispensing valve can be stuck or defective. Sometimes jiggling the valve can make it stop running
Sep 30, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Whirlpool refrigerator won't make ice--just out of warranty
I would have to say control board but you could look for a bin level switch. This is what tells the machine that the ice Bin is full. If it is duty or damaged the machine will never make ice as it thinks there is enough already there
Sep 05, 2012 | Whirlpool Refrigerators
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water dispensor won't shut off.
IN THE BACK OF THE FRIDGE WERE THE WATER COMES IN THERE IS A VALVE WITH A SMALL PLUG ON IT.. YOU MAY HAVE 2 OF THESE THERE CALLED SOLENOIDS.. UN PLUG ONE OR BOTH, ONE IS FOR ICE THE OTHER IS FOR WATER.. FIND THE ONE THAT IS NOT WORKING RIGHT AND SOMETIMES YOU CAN CLEAN THEM OUT
Jun 27, 2011 | Whirlpool Refrigerators
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Fridge model ED5VHGXMQ00. It just stopped making ice
Hello Mike more then likely you have a bad water inlet valve it’s in the back of the refrigerator now if you change the valve and it still won’t work the water line may be frozen you have to defrost the freezer to correct this problem
Nov 18, 2017 | Whirlpool ED5FTGX Side by Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
