Question about Frigidaire ATF6000ES Front Load Washer
Water is spraying out of the water intake valve on my frigidaire front load washer
When i turn on the cold water it drips real bad and when i turn on the hot water it shoots everywhere
  • Frigidaire Master
  • 5,323 Answers
WERE THEY SCREWED ON PROPERLY
Posted on Mar 31, 2015
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
SOURCE: frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Posted on Dec 06, 2009
beltronic205
  • 1474 Answers
SOURCE: i transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Posted on Apr 08, 2010
marka19
  • 1430 Answers
SOURCE: Have a Frigidaire Top Load Washer model # glws1349as
Enter in your model # at www.appliancehelponline.com
You need a new water inlet valve part # AP3363282 All parts come with installation instructions.
Posted on Apr 09, 2010
Testimonial: "Thanks a bunch. I'll order the part and give it a go!!!"
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire front load washer won't fill with water
    http://www.washerhelp.co.uk/diy-repair-help.html
    Posted on Aug 21, 2012
    Water intake valve
    CHECK THE HOSE RUBBER SEALS GASKETS
    Apr 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Cold water intake valve is dripping
    Possible that the valve is faulty, or that the bandage or hose connection is not tight . You can remove and use some tape to reset the connection, if the water drips further from the valve then it can be due to faulty inlet valve. If so replace the valve.
    Jan 15, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
    Frigidaire gallery front load washer does not use cold water when cold cycle is selected.
    Either the cold water valve selenoid is not working or the control panal is bad. try swapping the hot and cold hoses and then call for hot water, if it fill with cold then the cold water valve is probably bad.
    Apr 28, 2011 | Washing Machines
    Frigidaire fwsb5700ds0 top load washer is dripping water from the water fill spout..why would this be occuring?
    sounds like you may have a bad inlet water valve the solenoid is not closing all the way... you may be able to try and shut water off and remove hoses and clean screens out of valve itself. first unplug unit and if water continues to drip then that is going to be your problem as that elements anything electrical energizing the valve and shows you have a faulty solenoid not closing all the way...\
    hope this helps good luck
    Jan 06, 2011 | Frigidaire FWSB5700DS Top Load Washer
    Will not draw cold water
    either the solenoid valve that controls the cold water intake is bad,the hose screen in the cold water hose is plugged or the hot/cold mix control isn't letting in cold water due to a voltage problem that sends power to the cold water solenoid valve to open it
    Apr 06, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
    Frigidaire washer hot water only
    sundsas if you have a bad temp select switch. only selecting hot/hot
    Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Water filling tub on washer
    First thing is to run the machine as normal. After the cycle is complete and the clothes are removed, turn the water off, hot and cold, to the machine. If on the next usage there is no water in the tub then the fault has been found. And, no, the water valves are fairly easy to access and replace if needed.
    Jan 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
    Water intake and wash cycle
    change the water intake valve, that is the only answer i think
    Oct 10, 2007 | GE Spacemaker WSLP1100D Top Load Washer
    Frigidaire ATF6000ES Front Load Washer Logo
    24 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
