Question about Samsung Galaxy Note 10.1"
My galaxy note color resolution is not complete or slow...what seems to be the problem.
I just bought it refurbished but the color configuration isnt adding up
  • Samsung Master
  • 3,320 Answers
Warranty exchange it.
Posted on Apr 13, 2014
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
My screen suddenly out of nowhere polarized and changed colors... seems to be functioning otherwise...
It sounds like their is moisture or clamyness inside the tablet. Let it lay in the sun bit with the screen downwards. See if it solves the problem.
Apr 01, 2014 | Samsung Metallic Gray Galaxy Note 10.1in...
Note 8 still freezes on startup screen after factory reset
you should call to company where you have bought or even better to go in with it
Mar 23, 2014 | Samsung Galaxy Note GT-N5110 16 GB Tablet...
Run slow
try to reset it to factory default...... but careful because everything is going to be erased
Mar 21, 2014 | Samsung Galaxy 10 inch Tablet Wifi...
Samsung tablet note 2 won't turn on
Steven,
I am not an expert with the Galaxy Note since I just own a Galaxy 2 Tab. But I have some suggestions.
Have you recently updated Android? If so your problem may be due to an error in the updated code. Solution: Contact Samsung to report your problem. If your problem is not unique, then you will have to wait until the software is fixed and the new update becomes available; this was my problem {I could not shutdown my Galaxy; after the shutdown it would just do a restart. I let the battery run down completely and stored the Galaxy for over month, waiting for the software upgrade. When I was notified of the upgrade, I installed the upgrade and everything was fixed.}
If you are impatient, search the web for how to "reset" your device by holding down the power on/off switch and the +key volume, if I remember correctly. This will put you in a kind-of debug mode. Don't rely on my directions but google this until you get the complete procedure so you do it correctly and you have some understanding of what you are doing.
Hope this is helpful even though it is not "the" solution to your particular problem.
Mar 08, 2014 | Samsung Galaxy Tab 2
My battery isnt charging even though it says it is.
Try a different cable and a different charger if you have them. Also try just connecting it to a PC's USB port. Of course, the PC has to be turned on. Even though it will say that it isn't charging, it will charge very slowly this way as long as you're not using the Galaxy Note the whole time. So try that over night.
If none of those work, then you may have a bad battery in your Galaxy Note. How old is it? If it is still under warranty, you may be able to get it repaired for free.
Jan 11, 2014 | Samsung Galaxy Tab Tablet PC
My tablet will not charge up properly
Try to charge with the usb data cable connected to a computer.
Jun 24, 2013 | Samsung Galaxy Note 10.1"
My Samsung galaxynote 10.1 has gone blank after 4 days of purchase, how do i fix this
First point is to hook up the battery charger as after 4 days of use on a partially charged battery it would be flat.
May 11, 2013 | Samsung Galaxy Note 10.1"
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
My video quality is very poor can I fix this
The quality of the video you play depends on the quality of the video itself. If the resolution of the video you play is low then your tab cannot replace the missing pixels. Try playing high resolution videos.
If you think you're playing high quality videos and yet your tab still doesn't display it in high resolution, then there must be something wrong with either the setup or the device itself. In the later case, I recommend you consult the shop where you bought the tab from.
Hope this helps.
Apr 24, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Note 10.1" Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
