Question about Dell 1160w Mono Laser Printer
Printer is offline, will not connect
Ran mr. fixit, could not see any problems. Connect is grayed out
  • 36 Answers
Hook up USB cord to computer and reset it.
Posted on Apr 13, 2014
How to connect?
if you conect via parallel interface make sure to install the driver for the printer. if you connect via USB the computer should recognize the printer automatically and install the driver. if it stays offline try to use the other interface or a new cable. if it doesn't help your printer may be faulty and you need to replace the formatter board
Jul 22, 2014 | HP LaserJet 1200 Printer
My printer wont connect to the internet and it says i am offline but the blue light is on and i have a cannon mx432 printer
go to printer folder right click on that canon printer there is one tab use printer offline click on that tab it becomes use online printer
it solve ur problem
Aug 11, 2013 | Canon Office Equipment & Supplies
Epson printer offline
Hi Dear,
The Printer Offline reason is mention below read the properly and solve your problem.
  1. Check the power button of you Printer it should be On.
  2. Check the data cable it will plug properly.
  3. Go to the system and check the printer property and unchecked the "Use Printer Offline" option.
  4. Check the USB or Parallel cable properly connect with computer.
Thanks
Mar 27, 2012 | Office Equipment & Supplies
Printer offline
Hi
Try disconnecting the printer completely from power and from the PC.
Leave it as such for one hour.
Connect the printer again.
Check the connections and make sure its well connected.
Feb 24, 2012 | Brother MFC 7840W Printer
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
I cannot print with my deskjet F2200, its showing error-offline, please advise how can i rectify this printer problem..
error-offline means that the printer is not connected to the computer, so what info i need is this printer connected with a cord or wireless? also are you using the network to connect to the printer?
Jan 23, 2011 | GPS
My HP F380 printer is offline and won't print. How do I fix this problem?
Connect the printer to another usb port and make sure use printer offline is unchecked in the print job screen - file.
Nov 09, 2010 | HP DeskJet F380 All-In-One Printer
I cannot print to my printer...it says it is offline...how can i fix that? its connected to the network and all network cables are working fine...
may be you should check, in first, in the control panel / printer ; right click on the icon of your printer , verifier that it isn't setup in offline mode , otherwise i don't know ....
Jan 14, 2010 | HP LaserJet 1320 Printer
Printer is connected and on. Shows as offline.
Go to Control Panel
Open Printers and faxes
Right click on your printer icon
Uncheck Use Printer Offline
Check if the printer is working ( A restart may be needed)
Oct 06, 2009 | HP LaserJet 3055 All-In-One Printer
How do i connect 2 the internet?
first go to network connection view the connection it will disable\enable
Apr 26, 2009 | Sony PSP (Piano Black)
Dell 1160w Mono Laser Printer Logo
32 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
