Question about Garden
Need manual for 14.5 HP briggs&stratton- have vavle problem
    Guru:
  • 145 Answers
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 110 Answers
SOURCE: want a repair manual for a 17 hp briggs &
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Posted on Oct 03, 2009
rycgl
  • 1545 Answers
SOURCE: My briggs & Stratton star but they don not
Remove the brass bolt holding the carburetor bowl on and clean it real well. It has some very small holes in it that carry gas up to the carb and may be partially or completely clogged, causing your problem. All holes must be clear.
Posted on Jun 13, 2010
kel1guy2002
  • 3740 Answers
SOURCE: need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
Posted on May 10, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Briggs & Stratton Model 92502 3.5 HP Engine with
Hi hjconn...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 25, 2011
Briggs & Stratton 16.5 Motor workshop manual
go google and type in-- workshop manual for briggs and stratton 16.5 hp motor -- if there is a pdf version , down load it
remember that the manual will cover a range of hp motors so a manual may be 14-20 hp
Nov 03, 2016 | Briggs & Stratton Measuring Tools &...
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
HOW DO I GET A REPAIR MANUEL FOR A BRIGGS AND STRATTON 12 HP IC QUIET ENGINE
Try website for Briggs & Stratton. Or use Google Search for Briggs & Stratton 12 HP IC Quiet Engine Manual.
Oct 02, 2014 | Heating & Cooling
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
15.5 intek pushrods whitch one is for the intake vavle ?
Intake is aluminum, exhaust is steel. Set valves 1/4" past top dead center on compression stroke (both valves closed), intake (bottom) .003-.005, exhaust .005-.007
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
