Question about RCA F27440 27" TV
Picture has alot of red in it, even if i take all the color out
    Top Expert:
  • RCA Master
  • 74,887 Answers
Video output card fault. Check for any loose solder terminals at this card. Gopakumar Gopalan Google
Posted on Apr 13, 2014
Digital Lifestyle LT32323 screen color keeps going red
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable.
Aug 05, 2012 | Digital Lifestyle s LT32323 LCD TV
The pictur freezes to balck and white.
Tv have a colors wheel design into it.Tv make alots of noises like grinding,humming,buzzing or pictures freezes or lost colors or flashes black&white flashes within the pictures.The tv colors wheel it is dying and the colors disc is it warping and not spinning correctly inside it motor walls axis anymore.The tv colors wheel must be replaced.The tv colors wheel sit way back of the tv and have to take out alot mechanical parts out before even can come to it and change it.If u have no mechanical skills.Don't attemp change the tv colors wheel by ur self.Hire a tv tech.person to change it.
Jun 30, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Heard a pop and picture is black and white on my samsung 56" DLP model HLR5677W.
This tv have a colors wheel.The colors wheel is dead.The tv have squiling,motor loud noises and back&white picture.All the indication problems of the colors wheel is dead.Call the tv tech.to fix this problems,because have to take out alot of manchanical parts.Before even can get to the colors wheel out to replaced it.
Jul 17, 2010 | Samsung HL-R5677W 56" HDTV
No color
This tv have a colors wheels it dead,it spinning off of it axis.That why u getting black&white picture.Hire a tv tech. to change the colors wheel.Because it hard to change the colors wheel,u never done it before.Have to take out alots machanicals parts before even can get to the colors wheel to change it.
May 14, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
PHILIPS MAGNAVOX Picture Color Off
hi i hope i can help you?. please check the arial connection. may i please ask you if you open up . go to where the red light is and check for any adjusters.if you find turn down the red top tip if you use a mirror and place in front of the tv and tha t way you will see what is hapining.
May 08, 2009 | Philips Televison & Video
No sound beautiful picture
check color code cables be sure all cable match up with the right inputs red to red and white to white rca or HDMI will same you alot of problems but sure that your tv have HDMI outputs
Feb 04, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
To much red in the picture
Yes, either some resistor has changed and it's pulling down the blue and green or depending on how much red it could be a short on the red line. Also you can open back of set and try this. Each CRT's have a Focus Block with Screen control. Maybe you can turn down red and align up with blue and green. The professional way of doing color is to get a good grey scale, meaning black and white picture. THis is turning down you color on set to zero and looking and adjusting to black and white as good as possible. You can try this but if there is a serious problem it may not help. The problem may have to be resolved first. Be very careful in touching anything while set is on, unfortunatly you have to have the set on to properly adjust. but you can use something plastic or rubber end screw drivers
Sep 06, 2007 | Mitsubishi WS-65411 65" Rear Projection...
RCA F27440 27" TV Logo
15 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
