Question about Oregon Scientific SE331 Gaiam Zone Trainer 3.0, Blue, 1 ea
How to turn the watch off - Oregon Scientific SE331 Gaiam Zone Trainer 3.0, Blue, 1 ea
How do I turn a Casio watch on?
There is no button to turn a watch on/off . your watch may need a new battery .
Sep 05, 2015 | Casio Watches
How do i turn my watch on or should it of came turned on
You should have to turn the watch on. If it is not on, then you need a new battery.
Dec 24, 2013 | Ripcurl Rip Curl Trestles Oceansearch Tide...
How do I turn off beeps on my ekho E-15 watch
Go into the menu, turn off alarms, beeps and chimes.
Oct 10, 2012 | EKHO E-15 Heart Rate Monitor Watch
My outer ring will not turn on my new watch
it can only be turn counter clockwise, if it doesn't move, bring it to watch service center. i hope i had been helped you.
Aug 20, 2011 | Timex Expedition T46601 Watch
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
The background light comes on when placed in the vertical. I need to turn it off to save battery life
The Auto Light feature of your watch has been turned on. To turn it off, press and hold the button that is on the bottom right of your watch for about 2 seconds. In the upper right of the face of your watch is a circle with some text on it. There should be a down pointing triangle in the upper right of that circle. Below that triangle there should be a dark mark before you turn off the auto light. After you hold the lower right button down for the 2 seconds that dark mark should turn off. The Auto Light feature will also turn itself off after six hours to help you to conserve your battery life.
Mar 25, 2011 | Casio Sport Watch White Resin Watch for...
Can't turn off the alarm on a timex Expedition Watch
buy a Casio wrist watch at KMart for around $17.00. They last five years, then the
band breaks and you buy a new watch. I timed the traffic signal system of our city for 20 years from a Casio wrist watch. Now in retirement, I have a Time Expedition which has several alarms which I do not need, and can't turn off. We change the time twice annually, so having alarms and chimes go off without warning ca bve a nuisance.I found some instructions on a website which shows how to turn the alarms off.
Jun 02, 2010 | Timex T41091 Expedition Watch
How to turn off alarm on g-shock casio watch
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 18, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Automatic light function.
There is a button below the face of the watch that has the atomic watch symbol on it. Hold this button down until you hear a beep and it will turn that function off. To turn it back on, press & hold the same button until you hear a beep.
Oct 15, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Oregon Scientific SE331 Gaiam Zone Trainer 3.0, Blue, 1 ea Logo
18 people viewed this question
Top Oregon Scientific Watches Experts
Jimmy Accardi
Are you an Oregon Scientific Watch Expert? Answer questions, earn points and help others
