Question about Kenmore 15343
Need the manual&user guide need to trouble shoot my machine , my machine was sewing fine and literally 5 minutes later and it was not sewing forward only in reverse !
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Kenmore Expert
  • 300 Answers
Make sure it is not in the buttonhole mode.
Posted on May 14, 2014
bilabon
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
talk2ginny
  • 34 Answers
SOURCE: need a sewing manual
I did a search and found a site that sell the manual you are looking for. I'm including a link: http://www.sewusa.com/Sewing_Machine_Manua/kenmore_Sewing_Machines_117_120_Models.htm.
I found it on Google buy searching for Kenmore sewing machine manuals.
Hope this helps. Ginny
Posted on Jan 31, 2009
  • 6 Answers
SOURCE: needing a user manual not service manual
Kenmores are pretty much alike
try looking at this manual
http://disruptit.com/manualgateway.cfm?pdfwanting=4038&username=anon&AV=123345&I=130.64.55.123
Posted on Jun 19, 2009
  • 30 Answers
SOURCE: I need a user manual for Kenmore sewing machine
You can download a manual from this site for $8, or buy a printed one for about $13, including shipping.
http://www.sewconsult.com/kenmore/158%20manuals/kenmore_instruction_manual_158_1941.html
Posted on Jun 22, 2009
mohammed387
  • 1952 Answers
SOURCE: thread goes off screw when i start sewing
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Kenmore Owners Manual
Posted on Jul 03, 2009
I need an electronic version for a Viking Sapphire 930 users manual and trouble shooting guide. Thank you
Husqvarna Viking has the manual for the Sapphire 930 on the product page: http://www.husqvarnaviking.com/en-US/Machines/SAPPHIRE-930 . The direct link to the User's Guide is http://www.husqvarnaviking.com/getattachment/Machines/SAPPHIRE-930/Sapphire930-manual-EN.pdf.aspx . The trouble-shooting section starts on page 51. For some issues, you may need to contact a service technician through a Husqvarna Viking dealer. Some parts are still available here: http://www.sewingpartsonline.com/viking-sapphire-930-parts.aspx .
I hope this helps.
Aug 30, 2017 | Sewing Machines
Machine sews but thread knots and the stiches don't connect.
Owner's manual is usually very descriptive and has trouble shooting section.
No owner's manual?, you'll need it some time later
Try: http://www.manualslib.com/
Mar 09, 2015 | Sewing Machines
Help trouble-shoot jammed machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
I am having trouble buttonholling on my Janome, it is new. It starts sewing and then stops and blinks 6L. What have I done wrong
Check your manual and follow the instructions. The error message may be listed in the trouble shooting at the back of the manual.
Probably will need to put on the buttonholing foot, pull down a lever which guides the machine to sew the length correctly and choose a buttonholing setting on the stitch selection.
Also, for good buttonholes, always interface the fabric to give it stability.
Mar 28, 2011 | Janome 8080 Computerized Sewing Machine
Stitch pattern is wrong
Here's the manual,
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Lets see if we can do some troubleshooting.
Have you checked your needle (size, for thread your using, material)
It sounds like a tension/settings issue, but could be as simple as poor thread quality. try changing the thread, and rewinding the bobbin. If using a silky material remember you need to back that up and make it stiff.
If this and a resetting of tension doesnt work,
Check your left side right side balance (pg 57)
Check page 84 on trouble shooting
Jan 27, 2009 | Singer 3116 Simple
Singer 3116 won't go into reverse
here is a download for your manual
pg 32 talks about sewing in reverse sewing.
but doesn't give much on trouble shooting other than hold the lever while sewing. If that's not the case, then I think your feed dogs are the issue. check your feed dog drop. pg 9 part 12
If you think the reverse lever is sloppy, professional action should be taken, (take it in to be repaired under warranty?)
I hope this was helpful.
Jan 11, 2009 | Singer 3116 Simple
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
