Question about Taylor 754-33 Ice Cream Machine Soft Serve H20 Cooled
My taylor yogurt machine freezes sometimes and then it stops freezing
My machine will freeze product sometimes then it will stop and it will be runny. Not sure what is making it do this. Someone said it could be a leak?
3 Suggested Answers
qasolution
  • 107 Answers
SOURCE: Taylor 8756 ice cream machine clogs at face
clean as per this manual http://www.taylor-company.com/service/resources/op_man/8752_8756_8757op0.pdf. if mix is over beaten will create ice crystals in mix which in turn could over time clog the door make sure you have adequate mix in barrel and its not freezing solid.Make sure all orings and springs are good and properly lubed in pump.
Posted on Apr 23, 2012
jawaidalvi
SOURCE: taylor soft serve trips breaker
COMPRESSOR IS GROUNDED.
Posted on Jul 29, 2012
Why my Taylor yogurt machine not freezing the yogurt. Model number 339 -58
if cooling light is coming on ck to see if chill plate is getting cold after a few minutes , also visually verify that agitator blades are moving mix around and over chill plate
(chill plate is inside round tunnel that mix bars go thru )
Jan 21, 2016 | Taylor Ice Cream Makers
Product comes out frozen after all night on standby in a 754 taylor
The same thing happened to my Taylor 8756 and it was the thermistor probe. The probe is a thin copper tube that is near the freeze cylinder. It cost me about $20 for the part and $200 for the labor to have a technician put it in. Hope this helps and good luck.
Apr 18, 2014 | Taylor 2001 754 Air Cooled Soft Serve...
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Taylor Icecream Machine Model# y754-27
Try slowing down the rate at which you are drawing the product from the machine,and giving it a minute or two between draws. If you take to much out to fast it starves the barrel and will cause it to freeze up,and that will make the belts squeal.
Dec 11, 2008 | Taylor 632-27 Ice Cream Maker
Ice Cream not freezing
Yes, they stop working sometimes. Same thing happened to me.
The Cuisinart ICE-20 bowl is precisely the same, and works with the Krups 337. You can buy the Cuisinart bowl separately. It costs nearly as much as the whole machine, but what can you do.
Jun 26, 2008 | Krups 358-70 La Glaciere 1.5 Quart Ice...
Taylor 754-33 Ice Cream Machine Soft Serve H20 Cooled Logo
43 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
