Question about HP Pavilion F1703 17" LCD Monitor
Thin white lines on HP f1703
How do I fix the thin horizontal line blurring my monitor?
BondoFox
  • 40 Answers
SOURCE: Black horizontal line
The LC display is bad. The monitor will have to be replaced.
Posted on Jun 25, 2007
  • 11 Answers
SOURCE: Shaking Problem with LCD Screen - HP Pavilion F1703
It sounds like you need to use your "DeGausse" button to reset the magnetics in the screen.
Posted on Dec 25, 2007
SOURCE: thin blue line
vertical line on my hp f2105, at first there was 2 on the left after 2 month another one came up in the middle and after 5 month onother one again came up on the right. this is a good monitor when it comes to design and picture but durability.... it is a failure.
Posted on Jan 19, 2008
jitenok
  • 151 Answers
SOURCE: HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 13, 2008
SOURCE: I have a thin line across the screen of my hp
Good question,
you can pick up Faulty hp laptop dv6000 for around 90 Euros on Ebay if you look around you might get Cheaper.
Just depends if your willing to do a little work or just wanna buy a new Laptop you can pick up a Handy Laptop now if you look around for 300 and up.
But a screen is not that Hard tyo change if you can do it or have a friend i suggest if its important to you Buy a Faulty laptop but see if any one locally can change it for you if not Buy a new one but look locally as you can use yours till it gets fixed should only take 1 hour to change :)
Posted on Jan 14, 2010
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
Jul 20, 2011 | HP w17e Monitor
Thin white lines on photos
Are the white lines horizontal or vertical?
Try to clean the contacts.
Horizontal lines = print carriage issue
Vertical = rollers
Feb 13, 2011 | HP Office Equipment & Supplies
I have white lines across the screen and a high pitch noise coming out of my monitor when it is powered on.
If the white lines are thin and possibly move up, then it Looks like you are getting static probably caused by a bad bulb in the lcd panel.
It may be a problem on the power board/ inverter.
You would have to open it up to possibly check for that.
If you open it and send me a picture to bammbamm@ptd.net, I may be able to see the problem.If not we can try a bulb test.
Fran
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
White horizontal lines of static on monitor
Can you try reducing your monitor refresh rate to a lower frequency, or the lowest frequency.
Apr 10, 2008 | HP Pavilion F1703 17" LCD Monitor
Mar 13, 2008 | HP L1706 17" LCD Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
