Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer and dryer..the washer has a leak... but it's coming from a whole in the outer plastic tub that houses the wash tub right in the plastic..not in a seam or a gasket or where a tube connects.. it's a hole the size of a nail.. like the kind you hammer boards together not hang a picture..is that suppose to be there is something plugged somewhere to that is an over flow... what...?
    Problem Solver:
  • 14 Answers
You might be talking about a pressure switch hose connector.
So the way to determine if that is the correct hole:
you have to find the pressure switch and find that slim hose (looks like a fuel delivery on small motors) and follow it all the way down. if it lays on the floor then this is the connection. if the hose you followed connects somewhere then obviously this hole was not meant for it. (only one option)
Posted on Nov 21, 2014
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Calypso GVW9959KL1 ruins clothes
I can assure you this IS a common problem. I can't tell you how many customers I have had in the past that complained about their Calypso's leaving the same marks on their clothing. The problem occurs because of the suction on the clothes as the washer extracts water from them during the final nunator cycle. The nunator is the wash plate that the clothes get caught in. The manufacturer's cure for this problem was to come up with a modified control board that reduces the final nunator time and minimizes the suction action on your clothing. The replacement control board part number is 8571359. I have ordered and installed this board on a few Calypso's. I'm surprised that nobody advised you of this in the past. If you call Whirpool back and they deny this, I got this information from them. It may be worth your while to contact them again to see if there is a recall on this and if they would cover the cost of the repairs.
Posted on Aug 22, 2008
SOURCE: whirlpool duet washing machine
I work at Whirlpool, and we recommend a product called Affresh to help eliminate washer odor. Affresh washer cleaner tablets break up many of the residues that bacteria, mildew and mold grow on, and it removes them, leaving you a cleaner washing machine.
For a limited time, they’re running a promotion on whirlpool’s website that will get you free shipping on a 3 –pack of Affresh tablets! You just enter EAF822 as the promo code, and they’ll ship you the packet at no cost to you!
Posted on Aug 26, 2008
GasPipe
  • 11 Answers
SOURCE: Banging while spinning and disintegrating gasket
Most likely not the drum bearing on this one.
I believe that your inner basket support has failed. It's a common problem on 4+ year old duet washers. This is by far the most labor intensive repair that can be done on the duet washer. You will need to tear down the machine for this repair. Expect it to be a four to eight hour job depending on your level of skill.
The basket is under lifetime warranty. The new basket will come w/the basket support already attached to it. Stupid as it sounds, You can't buy the bolt-on basket support alone, You need the entire basket! wtf?
The front section of the outer tub is supposed to have a 10yr warranty. Being that the tub was damaged by the basket, They may or may not warranty the parts.
Do a search on fixya. There is a guy from MA that has a complete set of pictures and info on the rotted/broken basket support.
Posted on Feb 25, 2009
bozcro
  • 867 Answers
SOURCE: whirlpool duet washer fills with water when not running
one of the control valves (hot or cold) is not closing the water supply, most likely leaking so the electronics are good. one of the valves needs replacing, but if you dont want to spend the money just shut the water supply off at the water supply taps.
Posted on Jul 17, 2009
  • 84 Answers
SOURCE: whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Posted on Dec 28, 2009
How do you remove the rear tub bearings on a whirlpool duet front loader. tub is out of washer but can't get shaft out
you have to buy the whole tub or basket,each part is around 230 dollars.the basket part number is W10250573 and it's around 215 dollars,this is the part with the shaft on it,the rear outer tub part number is 285984 and it's around 225 dollars.
Apr 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have a whirlpool front load duet washing machine. The white plastic around the drum is cracking and the machine is leaking from the front underside. Can this be repaired?
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer, inner stainless drum rubs
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
Whirlpool Duet Sport HT - Left Front occ. leaks a lot of water
hello. i dont have to tell you that these intermittent problems are often the most difficult to isolate ...........sooooooooooooo lets look at all of the possible causes for your machine leaking
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer very loud when spinning
No you do not have problems with your bearings (especially if you can rotate the basket and it rotates nice and smooth).
What has happened to your machine is exactly what happened to mine: One of the three 'legs' on the shaft support attached to the rear or the basket has broken. The reason it broke is because the bracket is made of die-cast aluminum alloy that is being attacked by galvanic corrosion. See attached pictures of the corroded shaft support, including a close-up of the break. This is what you will find when your machine is taken apart.
You can verify this failure mode by slowly rotating the basket and observing the position of the basket at its maximum off-center location. While the basket is at this position look at the back of the basket and you should see one of the three 'indents' located at the 12 o'clock position. While at this position you should be able to move the basket up and down. Now rotate the basket 120 deg so that the next 'indent' is positioned at the 12 o'clock position. The basket will now be more centered in the opening, and you will not be able to move the basket up and down. You have just identified which of the three bracket arms have been broken.
Call Whirlpool warranty service (1-800-253-1301) and tell them about the problem with the basket: believe it or not the basket has a life-time warranty. The shaft support is not available as a seperate item. The basket p/n is 8182232.
I was able to get Whirlpool to send me a replacement basket, but they would not do the same for the front-half of the plastic tub, which was damaged by the basket hitting the front lip, even though the warranty states that the plastic tub is warranteed for ten years. They did however agree to sell me one for 50% off the std cost. The p/n is 285982.
If your washer was purchased less than 5 years ago, best to work with your local Whirlpool authorized service agent to get the machine repaired. My machine is over 5 years old (GHW9100LW1), and I am repairing the machine myself.
I would be interested in hearing how you make out in getting your washer repaired.
Regards,
Bill in Ma.
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool Duet GHW9150P Front Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
