Question about Kenwood DNX7100 Car Video Player
Bypass parking brake
I hooked the light green -parking wire to black wire ground and still not b y passing the vedio video
  • 6 Answers
SOURCE: Kenwood DDX6019 no screen function
Grounding the wire out is probably not good enough unless this is an old model. The newer units require the parking brake lead from the head unit to be wired into a toggle switch. Take the lead wire it to one of the switch terminals, then wire the other terminal to the head unit ground wire. To make it work, simply toggle the switch twice-one up then down again. This imitates the parking brake being set. This is a dopey but effective illustration:
http://i132.photobucket.com/albums/q21/kthanid212/img057.jpg
This should get your screen working without the parking brake on.
Posted on May 08, 2008
Drew_1
  • 10 Answers
SOURCE: how do i bypass the parking brake switch in order for my video to play
run a jumper to GROUND from that lead. it must remain shorted all the time you intend on watching the dvd player. With that said, I have one in my car that is hooked up that way and I put mine on a toggle switch so that, in the event I get pulled over I can hit the switch and it won't work unless I pull the brake. If you get caught wacthing a movie while moving, there is a fine associated with it! just letting you know. but its very kool to have it on long trips.
Posted on Mar 03, 2009
SOURCE: DDX512 Video Playback Bypass
Yeah jus ground the wire, thats what i did
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: bypass for video on a kenwood ddx-512 car dvd player
On the wiring harness there is a green parking sensor wire (PRK SW) that you have to hook up. All you have to do is ground that anywhere on the chassis of the car then youll be set.
Posted on May 09, 2009
  • 6 Answers
Brown
Posted on May 31, 2009
How do you bypass the parking brake hook up on the Pioneer AVHP3200BT so dvds can be viewed while driving?
you need to toggle the ground. can be accomplished with a regular relay: pins 85 & 30 -> ground, 86 -> remote turnon, 87 -> green parking brake wire
Mar 21, 2011 | Pioneer AVHP3200BT Car Video Player
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
Sep 27, 2009 | Car Audio & Video
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Panasonic CQ-VD7005U in dash dvd 7'' touch screen
Connect the light blue parking brake wire coming out of the back of the radio to the black ground wire also out of the radio to the black ground wire on the wiring harness.... Basically just ground the parking brake wire.. Itll work, I promise. I have the 7001u.
Dec 03, 2007 | Panasonic CQ-Vd7001U
How to play dvd while driving
connect the pink wire to the black wire
Nov 08, 2007 | Pioneer AVIC-D3 Car DVD Player
HOW TO UNLOCK MY VR3 RADIO TO PLAY DVD MODEL VRVD630
The brown wire labeled parking brake -12v should be connected to the parking brake switch. So that to watch a DVD the parking brake needs to be set. but can be bypassed by connecting to ground.
if connected to the lights it could be your problem
nels
Oct 16, 2007 | Kenwood KDC-MP228 CD Player
Bypassing the parking brake feature
just earth the handbrake cable (light green) on a good earth point.
May 01, 2007 | JVC KD-AVX1 Car DVD Player
Kenwood DNX7100 Car Video Player Logo
46 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
