Question about Gateway M-6750 PC Notebook
Wont start When plugged in, there's a pink light on the front. When I press the power button and the pink light turns off, but wont start???
  • Gateway Master
  • 3,320 Answers
Gateway user guides are available at Gateway's web site. You need your compters information to access it.
Looks like a power supply issue.
Posted on Apr 13, 2014
2 Suggested Answers
SOURCE: My Gateway M-6847 will not
my gateway m-6847 does not turn on at all. no lights turn on. the ac adapter light turns green when plugged in the outlet, so that is not the issue. even if i try to charge it, nothing happens. It's just dead!!! any suggestions will be appreciated.
Posted on Jul 18, 2013
Why wont my ipod turn on
Try to continue to plug the charger but also press and hold the power and home button at the same time for about 10-15 seconds until you see the ipod restart.
Jan 22, 2014 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
My phillips 51pp9100d wont powerer on, the powrer button blinks nine times thats it
Try turning the power on using both the remote and the power button on the front of the set. if the set turns on using the power button on the front of the set, there is a problem with your remote.
If the set turns on using the remote but not the POWER button on the front of the set you may
If the LED light on the front of the set blinks but does not turn on when you press the POWER button on the remote or front of the set If the LED light does not blink when you press the POWER button try unplugging the set from the power outlet for 10 seconds. You should also try plugging a lamp or other electrical appliance into the outlet to make sure there is not a problem with the outlet. Sometimes an electrostatic discharge may cause the set to lock up and disconnecting the power resets the set. If problem persist, If using a surge protector, try plugging the set directly into the wall outlet. An electrostatic discharge could have tripped the breaker in the surge protector.
Sep 01, 2011 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
Toshiba PA3362U laptop wont start up ? My son left it turned on for 10 days without my knowing. I try to start uo but the inly response is alittle flashing light at the front and that stopsafter a few...
Make sure your plugged in and the battery is charged up. Usually the laptop won't stay on for ten days because the battery needs recharging. Press the power button for about 5 seconds then try pressing the power button again to restart what happens?
Jan 09, 2010 | Computers & Internet
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
Drum light stays on and wont let me start it again. Its dead but has light.. I have to power down the entire house to get it to start again
I had the same problem. LG addressed the problems as follows:
1. Unplug the unit 2. Press and hold the power button for 10 seconds. 3. Plug the unit back in.
It WORKS!! It's like reseting your computer or alarm clock. You've got to kill the power and press and hold the on button while it's still unplugged.
Hope this works for you.
May 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
Gateway M-6750  PC Notebook Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
