Question about Honda Black Max 3000 Psi Pressure Washer
Black max 3000 honda pressure washer won't start
    Sergeant:
  • 415 Answers
You need two things for the engine to start, spark and fuel. Pull the plug, hold it close to the engine and pull the starter cord- check for spark. If there is spark (most likely there wil be spark), then it is a fuel problem. Try a little startiing fluid into the breather and see if that gets it to start. If that works, then the problem is in the carbureator - it probably needs to be rebuilt if the engine has been sitting for a while.
Posted on Apr 14, 2014
  • 174 Answers
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
Posted on Jun 05, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 5603 Answers
SOURCE: pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
Posted on May 16, 2010
  • 50 Answers
SOURCE: we have a Black Max 3000 psi with a Honda GC 190
cud b a few things 1.check filter 2.check 2 c if water is returning tru the over flow 3screw down pressure valve as far as u can
Posted on Aug 02, 2010
LandaNW
  • 45 Answers
SOURCE: 13 hp honda pressure washer
There are a couple of things that can cause this problem. The first thing to check is if you are loosing spark. Dying after it gets hot sounds like to stater is failing in the engine. If you loose spark this is more than likely the issue. If you are not loosing spark you need to check the fuel system. Dying after 20 seconds it could also be a plugged main jet in the carb. Another common issue on Honda engines is a faulty vent on the gas caps for engines sold from around 2008 - late 2010. If your gas cap is only about 3/8" thick this is very likely to be your issue. Try running the engine without the gas cap on to see if it still dies. If not that is your problem.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Posted on Feb 13, 2011
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
Gcv160
Clean it up real well and try again. Most likely the oil is from the motor being put in a position that allows the oil to run into spots that it is not supposed to be in.
May 17, 2013 | Honda Black Max 2600 PSI Pressure Washer
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
I have oil in the muffler and when it starts there is alot of white smoke.
sounds like the piston rings are worn, and oil is seeping past them.
Try putting redex in with the fuel to see if that helps (might help clean the system).
Failing that, pop into Halfords and by a can of ?? (can't remember the name, but it's designed to take up the wear between cylinder and rings)
Hope this helps.
Jul 07, 2011 | Honda Black Max 3000 Psi Pressure Washer
How do you drainoil so you can change the oil in Honda Black Max 2600 pressure washer?
lornaa, you can get a copy of the user manual from this link. It has come directly from the manufacturer.
thanks and good luck
iain
May 04, 2011 | Honda Black Max 2600 PSI Pressure Washer
What type of oil can i use
The engine and the pump can use the same oil. SAE 30 non detergent oil. No need to pay more for speciality oil. Check oil often and look for any unusual signs such as milky or foamy oil in pump which would indicate water leaking past seals. Good luck.
Sep 04, 2010 | Honda Black Max 3000 Psi Pressure Washer
We have a Black Max 3000 psi with a Honda GC 190 engine and the water will not come out of the power washer anymore
Aug 02, 2010 | Honda Black Max 3000 Psi Pressure Washer
Honda Black Max 3000 Psi Pressure Washer Logo
118 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
