Question about Novelty Lava Desk Lamp
My tornado lava lamp doesn't work. A little plastic piece just bounces around on the bottom.
It's supposed to make a vortex but doesn't. Does it need to heat up? Is the plastic piece inside the lamp supposed to be stationary?
  • 1 more comment
  • Anonymous Jun 19, 2015
    This question is about the tornado lamp made by Lava Lamp company. It has the spinning vortex. Can anyone help us with solution to the spinner stopping? Again, not a traditional wax/water/heat lamp, but the type that spins. Thank you.
  • jo smith Oct 02, 2016
    Hi there - I just had this problem, following dropping it: There is a spinning motor with a magnet underneath the bottle which should in turn spin the plastic part inside the bottle. I had to lift the bottle off the base (unplug it!) and I found some springs had become stuck onto the motor magnet. I lifted the whole lighting/motor unit up and placed the springs into the three holes where they must have come from, then replaced the unit down onto the springs. I put the bottle back onto the base. Switched on and all ok. Hope that helps?
  • Ingrid Chambers
    Ingrid Chambers Jul 13, 2017
    Hey JO Smith, how did you get the bottle off of the base???
    Scholar:
  • 126 Answers
It's difficult to say based on your limited description. A lava lamp is a first of all, a lamp. Does the incandescent lamp light up? If not, replace it (it's the heat source which creates the swirling action in the attached "lava" globe). As for the plastic piece, perhaps it's part of the lamp-holder socket that broke off due to heat. Perhaps part of the switch.
In any case, the light light bulb probably burnt out. Believe it a standard 40 watt bulb, but be absolutely certain to check before replacing as you do not want to put a bulb with a higher wattage in there due to the confined space inside the lamp.
Posted on May 05, 2014
3 Suggested Answers
  • 39 Answers
SOURCE: Lava Lamp is new, only turned on 3 times. Larger
The coil spring in the bottom helps to spread the heat through the blob. Once it has been displaced it will take quite some time for the blob to liquify enough for the coil to be able to settle back to the bottom. It may take as long as two hours for an extra-large one to liquify. You will have to be very patient, but turn the lamp on and LEAVE IT ALONE.
Posted on Aug 09, 2010
woobie dog
  • 1273 Answers
SOURCE: Lava Lamp is new, not working, spring loose on bottom, no blobs
The lamp is made of wax and alcohol. Try inverting the bottle several times. The aim is to get the wax to fall to the bottom. Try shaking it, especially when the fluid is warm. This may help break the wax up to where it can begin cycling on its own.....careful, though, you don't want to burn your hand. I have done this several times, and it works!
Best regards, --W/D--
Posted on Jul 31, 2009
Lava lamp
Lava lamps get very hot. They get hot enough to melt the wax inside. They have very little insulation.
Jul 06, 2014 | Home
VORTEX LAVA LAMP STOPPED WORKING
lamps run on a small 25W bulb
Should be able to replace with little problems
May 21, 2014 | Home
I don't know how to make a whirling tornado in a bottle
1. take one plastic bottle and remove the water and cap 2. fill it 2/3 way with water 3. put a single drop of dishwashing soap in the water 4. put the cap back on the bottle and make sure it's VERY VERY TIGHT! 5. spin the bottle in a circular motion you should now have a tornado!
May 03, 2011 | Tornado (20) Vortex Tube - Create Tornado...
I am doing a science fair project called tornado in a tube what would be the hypothesis be !!
There are many answers to that, but you first need to decide what you are testing. Every experiment has a purpose. What can the vortex tube explain? What causes it? How does a real tornado act in comparison? ... The possibilities are endless. Think of the question you want answered, and the hypothesis is your guess of the answer before testing.
Mar 10, 2011 | Tornado (20) Vortex Tube Tornado Cyclone...
My Braun electric kettle won't click on. Do I need to replace the kettle or is there some way it can be fixed?
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Jan 16, 2011 | Braun WK200 Cordless Electric Kettle
Lava lamp problems
If it has been shaken or tuned over, then the liquid has mixed with the wax, which is why is doesn't circulate. You may be able to fix this by turning the lamp on until the lava starts to break up, then turning if off and letting it cool. Repeat this up to six times to get the liquid and the wax to separate. However, it may be irreversible.
Mar 07, 2010 | Toys
Jul 31, 2009 | Novelty Lava Desk Lamp
Blurry photos, delay in capture
These Sony cameras including T70, T100, T200, T300 all have the same problem. There is a little black circular plastic piece in the lens that comes off the place where it is supposed to be. The piece moves around inside the lens and the focusing element can't freely move under the pull of the spring and the lens can't focus anymore. This happens after a good shake. Lens may stop focusing if dust gets in the focusing elements gear. This happens often if you put your camera in a dusty pocket, bag, purse etc.
Jul 21, 2009 | Sony Cyber-Shot DSC-T5 Digital Camera
2006 Prius rear door panel removal
the black plastic is removed my prying away from the hatch, start with the most bottom piece.
the instructions in the owners book for changing the lamps shows this as well.
there are many pop style plastic fasteners
Feb 05, 2009 | 2006 Toyota Prius
After installing a new ink cartridge my display shows cover open and the cover is closed therefore I can't print
did you take off the cover of the ink cartridge
IF it is ok
Please reinstall the printer driver
Nov 07, 2008 | Office Equipment & Supplies
Home Logo
1,834 people viewed this question
Top Novelty Home Experts
Jax Planet
Jax Planet
robert
Are you a Novelty Home Expert? Answer questions, earn points and help others
