Question about Measuring Tools & Sensors
Knocking engine I don't know where its coming from at a certain rpm it gets louder faster but then I can barely hear it 91 prelude si
No power loss it just started all of a sudden I took valve cover off but see everything looking good the knocking goes along with rpms
SOURCE: knock in engine
Will831,
Check your timing belt too, it might be loose already. My car had the same problem and thougt that engine was going bad on me. Tried also the additives but didn't help. So I did a litle invistagation to figure out where the knoking sound is comming from. It sounded near where the belts are. Opened the cover and voela! found the belt was loose - took it out - upon invistegation, belt was starting to wear out out - one of the teeth was starting to peel off. Replaced it, retightend it and replaced the belt tensioner too - so far it's been 4month now and still no knocking problem.
Hope this helps..
--Ed
Posted on Sep 09, 2008
  • 147 Answers
SOURCE: 4.7 liter jeep motor making tappinf sound and motor is missing
sounds like the lifters losed prime! here is a little trick that ive learned add a half off quirt off transmission fluid to the oil to prime the lifter
Posted on Nov 30, 2008
suterman
  • 158 Answers
SOURCE: I HAVE 02 TRAILBLAZER LTZ, AND IT JUST STARTED
Hello, I see you have a trailblaber with a knocking noise. It sounds like you have an electric fan clutch issue. Believe it or not your vehicle has an electric fan clutch. It looks just like the older non-electric but if you look on the driver side of the fan shroud that is the wire connector you see. It is an exspensive part just for the clutch but thats exactly what you are describing. It doesn't get louder just fast with rpms. Please rate my answer, Thank you
Posted on Mar 06, 2009
  • 7 Answers
SOURCE: Knocking noise. Overheated engine, warped heads,
overhaul
Posted on Oct 20, 2010
SOURCE: engine knocking noise in 2000 saab 9-3 SE?
It's a common problem with these cars i am actually fixing mine as of now. That car is all about oil pressure and when it is low you'll start to get a tap and or what sounds like a knock due to the lifters not having enough pressure. Try taking your oil pan off and check your oil pick up line going from the oil pan to the turbo. A lot of times it gets a lot of sludge build up and makes the pressure little to none. If that looks clear check the slump inside the oil pan and see if that has sludge build up. Well hope this helped
Posted on Jul 23, 2011
Is it Worth to invest for a new timing chain or new engine on my 2007 Chevrolet cobalt?
Hi, The loud knock you are hearing is typically refer to as "spinning a bearing" OK, sounds like that's what is supposed to happen I know, BUT, the bearing is called a shell hearing, it is the bearings that are used in the connecting rod to crank connection.. Now, the repair... it is most common to replace the engine in these cases. You can expect around $3000.00 to $ 3500.00, replace the engine.
Mar 03, 2015 | 2007 Chevrolet Chevrolet Cobalt LS
Loud knocking at back of motor
could be a cracked or broken flex plate
Apr 10, 2014 | 1997 Buick Park Avenue
1989 honda prelude si. Automatic,shakes real bad when stopped.has no power,pedal to floor barely goes over 30 mph. Smells of fuel,i removed the cat now car,starts at least,but still wants to die and rough...
If the shaking has been progressively getting worse i would start by checking the engine and transmission mounts for rips or tears. Smelling fuel and major loss of power would suggest that you have a fuel leak somewhere. The sending unit its self is a culprit that can be hard to locate so if in doubt check it as well.
Jan 29, 2013 | Cars & Trucks
1994 Honda Prelude si starting problems
Your starter motor is either not getting power or in need of replacement. Otherwise, there is nothing wrong with your car.
Also check your battery connections for no corrosion there as well as by the starter motor. Low voltage circuits in a car are extremely vulnerable to poor contact issues.
Mar 29, 2017 | Honda Prelude Cars & Trucks
Just got 1994 suburban with the 5.7L engine. It has 125k on the motor. I noticed it very sluggish and couldn't get out of it's own way. Now I hear a very loud knocking when it idles. Can anyone help me?
is knocking coming from the engine or transmission? does the knocking get louder when go faster? any lights on the dash on? what color smoke out exhaust? any wierd smells?
Sep 15, 2010 | 1994 GMC Suburban
Knocking noise from engine 1995 honda prelude
This may also be a warped flywheel.
Jun 15, 2009 | 1995 Honda Prelude
1997 mustang cobra engine ping
you have a rod knocking this is a serious problem the more you drive it the worse it will get
it could also be a warped push rod but thats a slim chance
May 01, 2009 | 1997 Ford Mustang Cobra
1979 cad fleetwood brougham knocking sound from,engine
Sometimes collapsed lifters or loose rocker arms can cause knocking sounds in an engine. However, the fact that there was a possible loss of oil pressure and that the knocking gets louder as the rpm's increase, would indicate that there is damage to a connecting rod bearing and possibly the crankshaft. If the latter is the case you are looking at a fairly substantial repair bill.
Apr 14, 2009 | 1990 Cadillac Fleetwood
Honda prelude si 1991
Hi you are going to need an idle air control motor. This motor/sensor is what holds your idle at the correct rpm at idle.
Mar 27, 2009 | 1991 Honda Prelude
95 prelude -- dash lights for speedometer and tach are out
Just fixed this myself. I found a used USDM meter/gauge out of a 1995 SI on EBAY for $200. However, I have a VTEC engine that redlines at 7500 RPM and the SI's redlines at 6500 RPM. Easy to fix by swapping the face plates inside of the meter/gauge. If your issue is the bulbs they cost a lot... around $250 each. But if your lights went out simultaneously then the bulbs are not the issue... it's the power supply where the bulbs plug into and that's located behind the drivers dash speaker (very easy to remove with only two screws holding it in). This part is more expensive at around $350, but cheaper than buying two bulbs. Scroll through every page of honda prelude listings on EBAY and you may just get lucky like I did. Hope this helps.
Mar 12, 2009 | 1994 Honda Prelude
Measuring Tools & Sensors Logo
105 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
