Question about Silicon Power Rugged Armor A80 1 TB 2.5-Inch USB 3.0 and USB 2.0 M
How do usb external drives work
Are they faster is 1tig a big hard drive
    Master:
  • 388 Answers
If you are comparing the USB drive to an internal drive, generally the USB drive is slower due to the USB connection not moving data as quickly as a internal hard drive which has a more direct connection to the motherboard. USB 3.0 is a significant upgrade over USB 2.0 in that it can handle higher data traffic.
1 TB is quite large.
Posted on Apr 13, 2014
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
The SimpleTech 160GB ext. drive has a usb 2.0 cable with a y plug. I can only plug in one but I use the additional power supply. I get a message at times telling me to use the usb 2.0 port for faster...
You are using the correct connection, the external power supply is powering the drive, so the USB cable is just handling data. I believe the message may be telling you that you will get faster performance using a USB 2.0 connection, it is probably sensing that your computer's USB port is USB 1.1.
Feb 24, 2011 | SimpleTech Signature Mini 160GB External...
Western Digital My Passport Essential SE External USB 2.0 Portable Black 720GB Hard Drive too slow..
Try plugging it into a high speed usb port, formating it with the size of your files in mind, so for instance if you have lots of big files, raise the allocation file size and visa versa, otherwise buy a faster one.
Jan 25, 2011 | Western Digital My Passport Essential SE...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
How do I use my simpletech external hard drive. I
I have a 500GB and a 1TB. Both drives if they work at all, is because you have to apply the power after usb is connected. The 500MB still good but the 1TB took a big dump.
Dec 31, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
What is a portable USB (2.0) hard drive ??? Is it just a big USB ? Please tell me everything about USB (2.0) hard drive.
First of all, USB is an interface, that can be used for various computer peripherals, like a mouse, keyboard, printer, storage devices etc. Additionally, the USB interface is able to deliver some power (5V 500mA), which is quite enough for many devices. USB 2.0 is the newer, faster version of the original USB 1.1 specification.
Now for USB storage. Basically there are two types on the market. First are Flash (solid-state devices), usually in form of a "dongle" (called pendrive, stick). They store information in semiconductor memory. Second are hard disks, just like the ones installed in desktop and laptop computers - they store information on magnetic media.
Hard disks in a small enclosure, equipped with special interface, that enables them to be connected via the USB interface, are "portable USB hard drives". Many of them can be powered from the USB socket alone, some need an additional power supply.
With today's technology, hard disks can have 10-20 times larger capacity than flash devices, so they are still indispensable when you want to store a lot of big files (like pictures, movies etc), or back up the contents of your computer's hard drive as a safety copy.
Nov 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Usb does not recognise external hard drive
try using all available USB ports......or install chipset driver of laptop...do reply back
Oct 05, 2009 | Toshiba Tecra 8200 Notebook
Simpletech External Drive now failing to connect with USB 2.0
Hello sir, let me give you some tips, you can dismantle it and get the HDD unit, buy a cheap external SATA usb hdd enclosure with USB 2.0 . Well all of them are 2.0 compatible (the unit without the HDD) and put it there. you can always keep the old one for posterity. hope this helps.
Aug 06, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Not recognized
This may not be the external hard drive issue. Check your USB driver, under device manager. You might need to upgrade the driver. If you plug your external to another computer, you will see that is it working ok. Just re-installing XP might have not installed USB drive properly.
Jun 19, 2009 | Fantom Drives G-Force (GF500EU) 500 GB USB...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Silicon Power Rugged Armor A80 1 TB 2.5-Inch USB 3.0 and USB 2.0 M Logo
41 people viewed this question
Top Silicon Power Computers & Internet Experts
David Payne
David Payne
Are you a Silicon Power Computer and Internet Expert? Answer questions, earn points and help others
