Question about Elica Palermo EPR628SS 29" Custom Hood Insert with 600 CFM, 3-Speed Internal Blower, 8.1 Sones, 2 Dishwasher Safe Filters, Halogen Lighting and Convertible Installation
Replacing the bulbs on my Range Hood Elica EPR628SS
Replacing light bulb
make sure the power is off and unscrew it with long nose pliers
Sep 10, 2013 | Maytag MMV5208WB - 2.0 Cu. Ft....
How to change the light in technika range hood
Safety is important when is comes to replacing a light bulb of a range hood. The first thing to remember is to turn off power and allow lights to cool before proceeding.
home light
Jun 03, 2012 | Kitchen Ranges
Don't know how to change a burnt out light in a new elica hood fan
Hi
I do not think this is a very big problem
just change the light
you win every time
kkv
kolla bolla
Aug 20, 2011 | Kitchen Ranges
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
I need to run my 7" venting 20 feet with 1- 45 and 1 - 90 elbows. Will this be acceptable or is the run to long?
Yes that will be acceptable. You just can not have 4 at 90 elbows or anything that will make 4 - 90 elbows.
May 31, 2010 | Zephyr Elica Om EOM-M80A Kitchen Hood
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
Elica Palermo EPR628SS 29" Custom Hood Insert with 600 CFM, 3-Speed Internal Blower, 8.1 Sones, 2 Dishwasher Safe Filters, Halogen Lighting and Convertible Installation Logo
91 people viewed this question
Top Elica Kitchen Ranges Experts
bobalix
ray gallant
Tom Chichester
Are you an Elica Kitchen Range Expert? Answer questions, earn points and help others
