Question about Epson Stylus CX5000 InkJet Photo Printer
Just replaced all ink cartridges on R320 Epsonstylus printer and the will not pritnd it will not print. Two cratridges show empty. Just bought them.
Printer will not print.
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Status Monitor says ALL ink cartridges empty
Using recycled ink cartridges in your inkjet printer is never a more economical way to do colour printing, unless you are willing to become a master technician on your particular product and have ready access to print heads and machine engine unit replacements, you will also need manufactures service software/website to reset waste counters/error codes.
It is expensive to print in colour full stop. Printing cost is at least 30cents inkjet and 10cents toner/laser per sheet
Laser b/w and colour is far cheaper per sheet, but setup costs are one time expensive but they are also a lot more reliable printing system.
Your machine will stuff up sooner rather than later when using non genuine consumable, and when it does it will cost more than the machines worth to even look for repair, so be prepared if choosing this road to purchasing a new printer every few cartridges if you are lucky.
If your using non genuine products and you want machine looked at by a professional the first thing you will need to do is install all genuine products in to your machine to allow correct fault diagnostics to be done, this is before any repair cost that maybe incurred.
Recycled/refills/aftermarket ink cartridge faults include – not recognizing ink, poor print quality, error codes, wont come to ready, erratic carriage movement, lines, waste counter issues and also paper feed problems, circuit board/connection faults caused by leaked ink .Not all faults are immediately apparent it takes time for the poison ink to replace that in the supply system then issues begin.
Cheap printing can be achieved using b/w lasers they cost less than 2 cent per sheet and have a brilliant reputation for print quality and dependability. Then if you need the occasional colour go to the shop, let them have the hassle, stress, time and expense of running the machines and the cost is still relatively cheap to you.
There are many consumers still printing with 10 year old laser machines, you would be extremely lucky to find a 3-5 year old inkjet.
If you must recycle well buy one that has already been proven to be adaptable to the concept, so that means go back to older units that went so clever.
Older Lexmarks, Epsons and HP were once easy targets, there was and is a lot of development gone into managing bulk ink deleivery systems, software has been cracked and parts can be sourced.
Inkmizer canon/epson bulk ink modified printers
Chipresetter be prepared for some frustrations and mess.
P.s. Most new machines come with starter inks that do not contain as much as new ones ussally 3ml instead of 5ml to enable cheaper selling cost, but also note that about 2ml of ink is in the tubes that run from ink carts to print head.
Posted on Dec 22, 2007
J PENGUIN
  • 12 Answers
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Posted on Dec 31, 2007
SOURCE: Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Posted on Apr 13, 2009
SOURCE: Epson CX3900 says all cartridges empty but not true
there are some good ink replacement available. better if you disable ink monitor if u use non original ink..yes, some epson wont print with one or more empty ink cartridge. the scanner in the 3 in 1 will still work. cns assoc is right somehow..
Posted on Feb 11, 2010
Ink empty after replacing ink cartridge
Printers often show 'ink empty' when a remanufactured cartridge is used. Usually the printer will still print but some makes have a block that stops this.
My Canon does the same but i ignore the message and it prints OK.
May 22, 2013 | Canon PIXMA Office Equipment & Supplies
Changed ink printer error on r320
Power off the printer, check for obstructions. Move the print head to the left side, then again check for obstructions. Make sure the cartridge cover is closed. Try to reinstall your inks, push them down the cartridge holder until they click.
Dec 09, 2010 | Epson Stylus Photo R320 InkJet Printer
HP 8250 Cannot Print - Printer Senses New Ink Cartridge as EMPTY
you need to have authentic hp cartridges,if you bought cheaper,it will not work.
Apr 23, 2017 | HP Photosmart 8250 InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
How to refill hp 920 cratridges for office jet 6000
Don't waste your time and money.
Use only factory new ink cartridges from HP.
Apart from voiding any warranty that may be left on the printer, you can end up replacing print heads and getting very poor quality images from your printer.
Don
Feb 01, 2010 | HP Officejet 6000 All-In-One InkJet...
Print cartridge error, keeps coming up, have tried new ink cratridge, and blowing out dust, what else can I do to get printer to work?
most new cartridge's come with a chip in the side. this tells the printer how low the ink is,
so if its empty the chip will tell the printer its empty no matter how u fill it up u need a chip reset not sure how to go about this ill look it up and send u the relavent information...
Sep 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Changing ink cartridge
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Epson Stylus  CX5000 InkJet Photo Printer Logo
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
