Question about GE JGBP33 Gas Kitchen Range
Replaced oven ignitor but still no heat on my GE JGSP28SEK2SS
Illeagle
  • 525 Answers
SOURCE: My ge gas range will not heat up
Inspect the ignitor for a crack or break in the continuity of a ceramic ignitor. If you can't visually discern a failure, then a multi-meter is need to check for resistance through the ignitor.
Posted on Jun 02, 2008
SOURCE: Similar problem but ignitor replacement did not fix mine
try the gas valve behind the storage drawer. it may be closed. that was my problem.
Posted on Aug 25, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
  • 221 Answers
SOURCE: GE XL44 gas oven we replaced the ignitor and the
Hi, this could still be a defective igniter, to verify you need a volt meter. The voltage being delivered to the oven gas valve must be at least 3.1 volts ac. Anything less and the valve operation is unreliable. If you have 3.1 to 3.3 volts to the valve when the thermostat is calling for heat and no gas, the valve needs to be replaced, If the voltage is lower, change the igniter.
Posted on Feb 02, 2010
SOURCE: how to change an ignitor on a XL44
I have the same problem,,, did you find a way? The screws are not readily accessible, there must be a trick.
Posted on Feb 07, 2010
We have a GE Spectra Profile 10 years old ( gas) and it will not heat up all you can do is broil
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 15, 2011 | GE 30 In Freestanding Gas Range ...
My oven will not light the oiven is a ge spectra XL44
heatman101
Apr 21, 2011 | GE Ovens
Ge gas oven ignites but flame does not come on to heat oven.
Oven not Working or
Oven not Heating
heatman101
Mar 10, 2011 | GE Ovens
I have a GE Spectra JGBP30WEA6WW and the oven doesn't ignite
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 10, 2010 | GE Ovens
Hotpoint XL44 -- the oven does not heat but the ignitor glows
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 09, 2010 | GE Ovens
My GE oven won't light
heatman101
Nov 11, 2010 | GE Ovens
GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
Ge spectra oven xl44 model # JGBP85WEB5WW oven will not heat
heatman101
Nov 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven won't heat up
hi atdowhower,for your oven to heat the[ignitor]must heat up enough to open the oven safty valve.this happens by the ignitor drawing enough amprage thru the safty valve.just because it glows it may not be strong enough.or if you see no glow it may have a broke coil in that ignitor and wont glow at all.you wll need an volt meter to check if no glow.if soft glow,replace ignitor.shoul be very brite.God bless,tom
Jan 02, 2009 | GE JGRS14 Gas Single Oven
GE JGBP33 Gas Kitchen Range Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
