Question about Haier Refrigerators
Fan won't turn on in chefmate mini fridge - Haier Refrigerators
4 Suggested Answers
  • 9 Answers
SOURCE: Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Posted on Dec 08, 2008
  • 286 Answers
SOURCE: chefmate mini fridge no more
OK If this is a U-line refrigerator. Is the compressor running? The Fan? If both are running then you will have a sealed system issue. If nothing is running then it goes to the thermostat. Bypass the 2 wires from the thermostat to see if it runs.Yes, then replace the thermostat.
Posted on Jul 22, 2009
miket756
  • 2702 Answers
SOURCE: I have a Chefmate Mini Fridge - BC-50A that does
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Posted on Nov 19, 2009
My Chefmate mini fridge has stopped working - no light no power, nothing.... any suggestions? Is it dead?
check for fuses or fusible links,trace the power and find where it stops
May 20, 2015 | Refrigerators
What is the coldest setting on a Chefmate mini fridge?
Well, mine is set to 1 and it freeze everything in the fridge! I'm going to try the opposite
Sep 10, 2014 | Refrigerators
Chefmate mini fridge quit
Toddm475... a hoarder (me too... )
It is indeed... (good to keep for parts)...
and actually fixing them is the ULTIMATE in recycling.
Just so long as you can still get the CAR into its garage.
THAT is the basic tenet for all us hoarders of
treasured artifacts (& other "STUFF")
Fortunately my wife keeps a close eye on me.
I have played with refrigeration for years on cars...
but did it the old fashion way...
Freon 12 & 22...
NOW I keep a (small) compressor just for the purpose
of moving my R22 from one device to another.
The refrigerator might not be that valuable...
but the FREON is pure gold...!!
Just a thought... Red & green lights mean you have
solid state circuitry... Low voltage hits TRANFORMERS
the hardest... VOLT-OHM METER...!!
Some folks... (like Harborfreight) give METERS away...
Just exactly what you need to measure across the transformer...
and to increase the depth & breadth of your cache of broken treasures (ready for restoration)...
They are watching us (good thing)
Carnac the Magnificent
May 23, 2017 | Refrigerators
I have a Chefmate BC-87/H mini fridge and I lost my Manual and I need to know if #1 is coolest or #9
jeeze! none of these idots who replied are reading your question!!! I have the same issue not sure which is warmer and which is colder. in my full size fridge, 1 is warmer, and the higher numbers are colder. if you found the solution though- i would really appreciate it if you could let me know! my email is mike41062@gmail.com... i have been searching for the user manual online and cant find it anywhere. cant even find a website for chefmate!!!
Sep 21, 2010 | Refrigerators
I have a Chefmate Mini Fridge - BC-50A that does not work. It appears the heat sink fan and the cold sink fan do not have power to the motor. What do I do? nicole.barnes@parknicollet.com
Nov 19, 2009 | LG GC-051SS Compact Refrigerator
Chefmate mini fridge no more
Jul 21, 2009 | U-Line 15R Compact Refrigerator
(1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Jan 12, 2009 | U-Line 15R Compact Refrigerator
Nov 03, 2008 | LG GC-051SS Compact Refrigerator
Refrigerators Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
