Question about Garden
Wont run only starts win gas porded in carb but dont run long
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Bad fuel pump
Blocked fuel filter
Blocked furl lines
No fuel
Bad fuel
Wrong fuel in tank
Vaccum leak or inlet manifold leak
Good luck
Posted on Apr 13, 2014
No fuel comeing out of injectorson carb
may i know the year and type of the vehicle
Oct 26, 2014 | Cars & Trucks
Mx-2721b gas generator carb kit
check for spark if spark squirt some starting fluid in carb dose it try to start or runs chang gas put fresh gas in it and seafoam carberator additve in it restart sameway let it run three tank fulls out then try to start it regular way if still dosnt wont to run rebuild carb this is how a shop would do it
Sep 02, 2014 | Electrical Supplies
My 86 honda 250 sx wont start. It will start if i use starting fluid for a second but thats it. Before it would shut down after rideing it for a few,so i took the carb off,cleaned it put it back on and it...
I would say that the incorrect of use of gasket goo instead of the proper gasket has spilled into the bowl after assembly and is blocking the main jet --again
when working on a carby , there is no successful "short cut or lazy action"
Mar 07, 2017 | ATVs
I have a 06 honda trx250ex put new gas and oil in it and plug and battery and iit turns over but wont start but when i put started fluid in where the plug goes it starts for like a second or so and quits...
your problem is a clogged carb. clean float valve, main jet and idle circuit with a can of spray carb cleaner.
disconnect fuel hose at carb and see if gas flows.
reconnect hose and open float bowl drain valve. If no gas tap on side of float bowl with plastic end of screwdirver to free up float.
still no gas? remove float bowl and try to shoot carb cleaner into the fitting for the gas line from tank.
if gas flows now then put it all back together and it should run
if not then remove carb and clean carb passages, main jet, idle circuit.
Mar 21, 2011 | 2006 Honda Xr 250
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
Gas in tank wont start unless put gas in carb-then
Hi, being a tiller theres a good possiblity that the line is glogged and if theres a line filter it could be plugged also. Another source of clogging is from old gas, ti can become a little varnished.
Remove the line clear it with compressed air or other source, drain the tank and if theres a line filter - replace it.
Another source could be the air filter - usually a sponge. Replace this as well or clean in a varsol bath. squeeze it out dry, then apply some oil to the input side - helps to catch dirt, etc.
USE safety precautions .
dont forget to vote
Oct 14, 2009 | Garden
1972 CB350... just put new battery in, new spark plugs,it will start but wont stay running, i think its only running on the left carb because the right exhaust pipe is cool. revving up the RPMs dont seem...
sounds like bad gas or gumed up carbs try a fuel cleaner and fresh gas fire it up open and throttle up hard to free up the gum on the carbs mine did the same thing ....
Sep 08, 2009 | 1972 Honda CB 350 F0
Bike has been standing for 18 months without the engine being spun. Bike will not start without choke. when choke is off engine stalls
You need to completely drain and refill the gas - the gas you have is stale and doesn't have enough power to run the bike.
The battery needs to be fully charged - not just jump started. It wouldn't hurt to do an oil and filter change as well as a air filter and plug change.
Jul 01, 2009 | 1995 Yamaha FZR 600
89 jeep yj wont keep running
sounds like you need to rebuild your carb. I just had mine done for my jeep the hardest part was finding someone to do it. ps mine only cost 50 bucks so dont get ripped off. good luck and hope this helps.
Apr 19, 2009 | 1990 Jeep Wagoneer Limited
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
