Question about Jenn-Air JGS8750ADS Gas Kitchen Range
Jenn-air gas range probe light f1-10 code
Jenn-air gas range probe light on the display pannel came on won't go
off it beep and show a f1-10 code.need help
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Beeping will not stop on jenn-air oven-remove probe flashes on, but probe is removed.
your probe socket may be shorted or wires going to it grounded to frame. Or your main computer board is NG.
Dec 12, 2009 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Sep 23, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Remove probe from oven
most electric ovens have a temperature sensing probe inside of them. this is to prevent the oven from overheating and causing a fire. the reason why it's asking you to do that is because it's either dislogged from its place or it need to be replaced.
Sep 13, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Dec 01, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air JGS8750ADS Gas Kitchen Range Logo
196 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
