Question about Acer Aspire One PC Notebook
External microphone still showing not found
Purchased an external microphone plugged it into the appropriate outlets, icon shows microphone, but person on the other end still cannot hear me
    Sergeant:
  • 231 Answers
Check this video
Posted on Apr 12, 2014
2 Suggested Answers
  • 788 Answers
SOURCE: I have an Acer Aspire 5720Z. The microphone will
The fact that your internal mic works and then goes out, is more likelly a drivers problem.
I would run your device manager with all external devices disconnected and look for flags.
If you have a device problem, it will show up here.
Remove and flags and allow your operating system to reload drivers after a reboot.
If this has not fixed your problem, try to boot into safe mode and check your internal sound devices their. Sounds like a driver conflect.
Hope this has helped,
Posted on Sep 25, 2009
Rec error code 6000 on pixma mg5420. Just purchased yesterday
It may be superficial for a question but did you remove the plastic film on the cartridge ?
Feb 02, 2015 | Office Equipment & Supplies
Built in mic not working
if u rt clk the speaker icon in the system tray and select 'recording devices' the window that opens will show any mics connected.
if internal 1 shows not connected then u may have a loose cable to the display - where the mic usually is located.
If it does not show at all u may have a driver issue.
Look at ur device manager for a warning sign icon. If found try to update driver.
Dec 10, 2013 | Fujitsu Computers & Internet
Built in microphone does not register
right click on the sound (speaker) icon on the bottom right hand side. Select recording devices. Right click on the microphone and click on "show disabled devices" and "show disconnected devices". You will find you built-in microphone has been disabled. Right click on the internal microphone icon to choose enable.
Jun 22, 2013 | Toshiba Satellite L645DS4040 Laptop
Monitor will not turn on
Monitor will not turn on as in NO Power? When you hit the Power Button the monitor power light does not come on? If so either the power cord is not plugged in good, maybe the outlet you have it plugged into the wall or power strip is not working, or the Monitor is bad and needs to be replaced.
If you are saying the monitor has power but the display is black then:
Look to see if it sounds like the computer is running but nothing is shown on the screen. If so try this:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 06, 2012 | Toshiba Satellite P35-S611 Notebook
Aiptek GSV 1080P HD Camcorder external mic feature won't work.
Possibly an impedance mis-match - check in both manuals.
Sep 27, 2017 | Video Cameras
Just purchased an ipod nano...how do I turn off the external speaker? even when I plug in the headphones, the external speaker stays on
Flick the button/switch on the top of the nano on and off 6 times leaving the orange bit not showing.
Now hold down the menu button and the middle button for 15 seconds until an apple2_bing.gif icon appears. SORTED!
now the speaker turns off when you plug the headphones in plus rest assured it doesn't reset the ipod and remove your songs.
Feb 28, 2010 | Apple iPod nano 4th Generation
I haven't a clue how to use the passport....the help on line doesn't explain....is there a manual I can download pls... It's registered but how do I download my pictures on to it??? I need...
Does this drive show up on your computer? Most of these external drives have a manual to be found on the drive. Look in your Computer icon for a new drive, mine is the "E" Drive, and once you find it you can explore it just like your Hard Drive.. Files like pictures can be dragged and dropped. Initially you just plug the AC power into the outlet, and the drive, then the USB cable from drive to computer's USB connector. The drive SHOULD be in your Computer icon of Windows.
Nov 03, 2009 | Western Digital Elements powered by WD 320...
External mike doesn't work
I'm assuming you have Windows Vista. If so, you may need to change the default microphone, particularly if you have a built-in microphone on the computer.
1. Right-click the speaker icon next to the clock in the system tray.
2. Select "Recording Devices"
3. Select "Microphone" or whatever item you want to record with.
There will be a VU meter showing the input level. Try talking into you mike and see if the VU meter goes up. If so, you're good to go.
If not:
1. Click the "Properties" button in the screen mentioned above
2. Move the "Volume" and "Boost" sliders up.
3. Click "OK."
4. Check your VU meter again.
If this does not work it is possible you selected the properties for the wrong device. Click on another device and repeat the last 4 steps again.
Jun 02, 2009 | Dell Inspiron 9300 Notebook
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Microphone is not working
  1. On the sound control pannel check your microphone settings if set on mute, uncheck this option.
  2. If problem still persist check computer hardware properties for the status of your device under sounds. If your not familiar with this just follow the steps.
- Right click my computer icon and select properties.
- click on the hardware tab
- click device manage button
- from list of device you can check the status by right
clicking and selecting the properties.
3. Reinstall device driver if no device found / problem with device.
4. If all steps have been considered and you have an external outlet for microphone try installing one just to check,
Jun 23, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire One  PC Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
