the fuel pump is in the gas tank and the fule filter runs along the bottom of the Driver side..if your looking at the gas tank follow the gas lines that go toward Eng. you will see the Fuel filter
Usually that is a bad fuel pump. Filter is not on the tank. Test it when it doesn't start, or listen, as when you first turn the key to "run", you should hear the fuel pump cycle.
1. Support the gas tank with a jack or something
2. unbolt the gas tank straps
3. unscrew the rubber filler neck going to gas tank
4. Lower gas tank slowly and disconnect gas lines
5. Turn the retainer ring that holds the fuel pump in the tank and left out.
6. Drain gas into gas cans to make the gas tank easier to left
7. Replace fuel pump and reinstall gas tank.
A FORD EQUIPED WITH DUAL TANKS THIS YEAR MODEL HAS CHECK VALVES IN THE FUEL PUMPS .THE FUEL RUNS FROM THE REAR TANK WHEN IT IS POWERED ON TO A TEE AND INTO THE SAME LINE AS THE FRONT PUMP . THE PROBLEM IS AT THE BOTTOM OF THE FRONT FUEL PUMP THERE IS A CHECK VALVE ON THE FOOT AND IT IS NOT WORKING.WHILE THE TRUCK IS RUNNING WITH THE REAR FUEL PUMP ON IT IS PUMPING FUEL INTO THE FRONT TANK . IT WILL RUN OUT OF THE NECK WHEN IT IS FULL.THE FIX IS SIMPLE REPLACE THE FRONT FUEL PUMP. THEY DONT MAKE A CHECK VALVE REPLACEMENT I CHECKED I HAD THE SAME PROBLEM AS YOU.
hi there,
this is to clear the idea,your fuel pump is located at inside you fuel tank.this is not easy job for replacement,have a precaution doing this there fuel inside your tank if you wanna do this or fix your self,you have to remove electical source by pulling out first the one pole or terminal of your battery.to prevent in any spark,using syphon pump,you can empty your fuel tank evacuate all fuel inside your tank before pulling out your fuel pump.figure showing fuel pump/
disconnect all electrical connection on fuel pump.have a nice day
