Question about Video Game Consoles & Games
PS3 / comcast
I have a PS3 and we have Comcast xfinity with the 50 mbps but my PS3 says on a connection test that it is only 25.5 mbps download connection speed and 6.6 connection speed and my on line game like Battlefield 4 seems to lag? What should my connection speed download be at. Everything else in my home like laptop my wireless tablet all seem to be at what is normal. Can anyone help me with this question.
    Master:
  • 665 Answers
Optimal speed is anything above 10mbps. I have Time warner 100mbps, but still only test out at 25mbps MAX. Make sure you are hard wired so you don't have signal interferance. I had a big issue with that while connected to wifi.
Posted on Apr 29, 2014
SOURCE: cnt hook up internet to ps3
I have comcast to what i did, because i had the same problem as you was I reboot my modem if you have a modem you can reboot it in the back but first unplug everything from the back all the cords then reboot it last. wait five minutes plug everthing back into plugs and you should get your connections back you would probably have to do this everything you connect to ps3 online hola back if it was helpful email DAUSRD@comcast.net
Posted on Jan 02, 2008
SOURCE: Unable to connect PS3 to my Secured WIreless Router
Go to this link... This worked for me...
http://maikelv.be/blog/2007/10/27/ps3-and-linksys-wrt54g-the-solution-2/
Posted on Mar 11, 2008
  • 5 Answers
SOURCE: cant connect my ps3 to the internet I have comcast
you need to be more specific. wireless? hardlined? NAT type? what type of router? what version of the ps3 do you have?
Posted on Apr 25, 2008
Agent Aaron
  • 265 Answers
SOURCE: How to wire a ps3
Hey allisc,
In order to connect your PS3 to the internet, you will need one of two things: a hard-wired connection, or a wireless residential gateway. Please keep in mind that your options may be limited by the PS3 model that you own, and that a wireless connection is not possible with some models.
The most straight-forward type of connection you can make is a hard-wired connection - simply use an Ethernet cable to connect your PS3 directly to your residential gateway. By establishing a direct connection, the PS3 should not need any additional information in order to access the internet. The trade-off for the simplicity of a hard-wired connection is that the number of places you can physically place the PS3 itself are limited by the length of Ethernet cable used.
Should you wish to use a wireless connection instead, you will need to own a 40GB, 60GB or 80GB PS3 and a wireless residential gateway. The 20GB model unfortunately does not support wireless capabilities at this time. Please keep in mind that connecting wirelessly can often prove to be more complex than using a direct connection, as you not only need the name of your router, but information on any established security settings as well.
The most common security settings that may be in place are Wi-Fi Protected Access (WPA) keys and Media Access Control (MAC) filters. MAC filters are essentially a series of "blacklists" and "whitelists" that restrict network access based on hardware configuration. WPA keys however, are "passwords" that allow your computer or video game console to decipher a code used by residential gateways which prevent unauthorized users from using your personal internet connection.
Both forms of security may typically be set and changed by accessing the gateway directly through its default website. This default website can vary depending on the brand of the device, but many companies may use one of the two default addresses I've provided below:
192.168.0.1
or
192.168.1.1
Please keep in mind that in order to access the gateway's control panel you will need to have both the admin user name and password!
Once you have gotten access to your residential gateway's control panel, you should then be able to add the MAC address of your PS3 to the gateway’s MAC filters, as well as copy down any WPA key used by the network so that you may later enter it into your PS3's memory.
If you are still not sure how to proceed or do not feel comfortable doing any of this, I would strongly suggest contacting either your internet service provider (ISP) or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
localwonder
  • 6784 Answers
SOURCE: xbox 360 keeps blacking the screen out for about 1
Hi, your X-BOX is overheating. this will continue to progress. Read the following details below to combat this issue before it ruins the gpu.
Alternativly Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
  1. Let the Xbox 360 console cool.
    Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
  2. Verify that the console has sufficient ventilation and that the fan is operating. For more information about ventilation, see the "More Information" section.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
  • Do not block any ventilation openings on the Xbox 360 console.
  • Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
  • Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
Posted on Jun 19, 2009
Need codes for my comcast remote
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!‎Comcast - ‎Find Your Comcast Remote ... - ‎Control Multiple Devices with a ...
Remote Control Help and Support ' XFINITY® by Comcast
Jan 18, 2016 | Televison & Video
How do i upgrade to78mb ?
Do you mean you are an Xfinity (Comcast) user?
Anyway, you might have some luck calling Comcast and asking them for a higher-bandwidth service, but really if you're connecting to your router over a wireless channel that will be your bottleneck since the 802.11g standard for wireless networking supports a maximum bandwidth of 54 Megabits per second (Mbps).
Jul 29, 2014 | Linksys WIRELESS-G WRT54GS 802.11G...
Comcast cable says they don't update firmware. l have a SB6141 motorola DOCSIS 3.00 and l just upgraded to 105 mbps. l'm hardwired to my modem. l'm only getting 32 power level ?
You may need to enable IPV6. All Comcast modem updates are done automatically. I would contact ARRIS for additional assistance. Comcast also has a helpful online community.
Mark
Motorola Mobility Support
Jun 18, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Albuquerqueward@comcast.net
Hi Evelyn,
For your case Comcast agents can reset it for you so please call them on this number to resolve your issue 1-800-XFINITY(1-800-934-6489). Former Comcast Tech Support here.
Jan 15, 2014 | Comcast XFINITY
My xfinity cable keeps freezing how do i fix it
If it keeps freezing you're going to need a replacement. Call comcast and have them replace it for you.
Mar 25, 2013 | Comcast XFINITY
Nuvision tv remote codes for xfinity remote
NVU55FX10LS use 10690 Comcast / Xfinity SILVER Remote with RED enter button
Jun 16, 2012 | Televison & Video
Video Game Consoles & Games Logo
49 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
