Question about Vizio Televison & Video
Vizio hdtv, soundtrack and background noise block dialog
I have low dialog and loud background noise on my panasonic sc-htb8 soundbar
That is a typical issue and not really fixable, it varies from video source to video source soundtracks.
Feb 21, 2017 | Panasonic Audio Players & Recorders
How to fix vizio tv buzzing noise and you can't listen to tv dialog?
Main power regulator board or back light inverter board can be the cause to this buzzing noise. Contact any service technician to troubleshoot. http://electronicshelponline.blogspot.com/
Jul 25, 2014 | Vizio P2 42 in. HD-Ready Plasma Television
My tv seems that almost all dialog is very quiet but background noise and commercials are far too loud. Any suggestions on how to adjust this?
You must either set the AUDIO settings to the optimum for your ROOM condition. In your case it is possible that the setting is preset to a spatial or wide setting. Set this for normal condition and the MID FREQUENCY which is the audible speech range will be boosted better.
Jul 27, 2011 | Vizio Televison & Video
I switched my ps3 from one tv to my vizio, and the voices of the characters arent being heard, but all of the background noise is. i have it hooked up with an hdmi cable, and the video is fine. i checked...
Shot in the dark here, but sometimes HDMI cables get a little discombobulated... Try doing a hot plug by powering both the TV and the PS3 up and then removing the HDMI cable from both of them at the same time. Wait 1 minute, then plug them both back in at the same time. Good luck!
Jul 21, 2011 | Vizio M221NV 22 in. HDTV LCD TV
CVizio 32" background lamp won't stay on
Ur backlight inverter ic board is dead must be replace.
Aug 31, 2009 | Vizio L32 32 in. LCD HDTV
Sound for DVDs
Turn Off or change surround sound mode in DVD system to get vocal sound (dialogues) in speakers.
Jun 03, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sound Problems with 32" Vizio HDTV
our brand new Vizio 32 HDTV has poor sound quality, so irritating in it's flat muffled character that I can't watch it. My electrical engineer husband as attempted to change it (he does not hear the difference between the Vizio and our two Sony...there is a BIG difference) by turning off the surround sound. But to me nothing has changed. What do you think? it sounds a little bit like an old radio or a broadcast from inside a closet. Hmmm
Jan 08, 2009 | Vizio L32 32 in. LCD HDTV
Dvd player
I assume the above problem is on all DVD's. Generally speaking, dialogue soundtrack is located in the Front Center speaker. From your description of the problem I would double check all the wiring to the front center speaker you have connected to your audio system. If there is no front center speaker, check to see how your audio system is set to handle the front center speaker . . . it should be set to "Phantom" or "none". On the other hand you're relying just on your TV speakers and you're not getting any dialog I would change, under the Settings of the DVD player, the Digital Out settings to PCM.
Jun 09, 2008 | Sanyo DWM-390 DVD Player
Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Nov 19, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
14 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
