How do I set the clock on my alba ccd216dab alarm clock to 24 hours, instead of 12 hours?
As this is an old model, I don't know where the instructions are. I just moved house and so it has been unplugged for several hours. When I try to reset the time, it will only go up to 12 then has a light indicating the afternoon, but I prefer it at 24 hours. Help?!
SOURCE: Clock format
24 hour mode is all there is. Time to learn military time.
Posted on Feb 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Smart set alarm clock - resetting instruction
First, make sure the time is set correctly – Eastern Standard Time (EST) is the default
Press the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
Posted on Jan 15, 2009
SOURCE: Setting the time to 12hr instead of 24hr
according to my manual there isn't an option for 12 hour settings only the 24. I know, it's pretty dumb!
Posted on Apr 07, 2009
SOURCE: Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Posted on May 06, 2009
SOURCE: alarm clock settings need changing, no instruction manual
In the top left corner there will be some bars showing that the hour anouncement is on. Simply press the minute button and these bars will go, leaving you in peace and quiet.
Posted on Mar 04, 2010
NEC PXT42SPKR
sadly we have no idea if it was 110 or 220 . try searching thru Google
Sep 11, 2017 | Televison & Video
Kenmore side by side - model - 253.54739304. we moved it from one house to another. it was working fine. now won't freeze or cool properly. like it is in defrost mode. compressor was not running...
if while moving it , you laid it on its side, it collected air in the lines, having it unplugged is a good idea, normally 24 hours is enough for the air to settle,, try it again after that time,
Jul 09, 2011 | Refrigerators
My KitchenAid model # KTRS20K refrigerator is freezing everything in the refrigerator. Do you know what the problem could be? I have cleaned the coils...unplugged and defrosted for 24 hours, adjusted...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 03, 2011 | KitchenAid Refrigerators
Model 385.15718500..machine only goes in reverse
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this, but as this is only 3 years old, should respond quickly
Aug 02, 2009 | Sewing Machines
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Shutting down fridge/freezer when moving house
    Other than un-hooking the power and any other connection like water, then defrosting to get rid of any ice buildup then prep for moving...the only thing you have to be aware of is transporting it in an unright position to protect the condenser. Here are the steps:
    1. Remove all food from the refrigerator and pack all
    frozen food in dry ice.
    2. Depending on your model, turn the thermostat control
    (refrigerator control) to OFF. See the Setting the
    Controls section.
    3. Unplug the refrigerator.
    4. Clean, wipe and dry thoroughly.
    5. Take out all removable parts, wrap them well and tape
    them together so they don’t shift and rattle during the
    move.
    6. Depending on the model, raise the front of the
    refrigerator so it rolls more easily OR screw in the
    leveling legs all the way so they don’t scrape the floor.
    See the Door Closing section.
    7. Tape the doors shut and tape the power cord to the
    refrigerator cabinet.
    Apr 24, 2009 | Freezers
    Fridge quit cooling after i moved it
    did you tilt it when you moved it and then when u got it in place plug it in? if so youve got compressor problems, anytime you tilt a fridge you have to let it set for several hours to allow the oil to get back to the compressor or you ruin the compressor
    Jan 01, 2009 | Refrigerators
    It s not working at all.
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
    Please reply back with your brand and model number so we can help you.
    Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
    Nov 21, 2008 | Microwave Ovens
    Have a philips(model 55pp9401) 55 in screen.just had the color (guns/chips/moduals?)changed because the blue was warping the top of the screen,also had some burned transisters.seemed to work just great...
    unplug the convergence yoke plugs all 3 of them and then see if the set powers up. If it does the troubles in the convergence circuits if it doesnt you likely have a problem with the LSB pc board. If you need more help let me know.
    Jul 02, 2008 | Televison & Video
    LAST NIGHT OUR LESS THAN 1 YR OLD MAGIC CHEF MICROWAVE TURNED ON BY ITSELF AND WE TRIED EVERYTHING TO GET IT TO CANCEL INCLUDING UNPLUGGING IT SEVERAL TIMES. IT HAS A MIND OF ITS OWN NOW. MODEL #MC0160UB...
    Have you looked on the magic chef recall website? I read about the same problem on the Samsung recall website about microwaves turning themselves on.
    Apr 01, 2008 | Microwave Ovens
    Televison & Video Logo
    Top Televison & Video Experts
