Cam timing, just put in new chain,,,to set the vales in time,
  • 957 Answers
You need to bring cylinder #1 to top dead center on compression stroke. then line up the timing marks were the chain goes u will see the marks. after u line up marks put chain on, be sure that u have marks lined up right being off even one tooth and car will be out of time.
Posted on Apr 17, 2014
I put new timing chains in the complete set new gears and all how do I get the secondary chains timed to the primary chain is there a specific way the gears go back on the cams for the primary chain
re ask the question and include the make model and year of the engine that you are working on as different makers have different procedures
Sep 01, 2015 | Cars & Trucks
How to remove the timeing chian
22R 4 cyl.Get # 1 piston to TDC(stick the harmonic balancer back on temporary)setting the mark to O on the timing tab,pull the balancer back off and slip the chain on the crank gear after finding the single dot on the chain.Set the mark on the cam gear at very top and put the chain mark on that mark on the cam gear.Stick the cam gear back on the cam and bolt it back on.Your set now.
Apr 11, 2014 | Toyota Hilux Cars & Trucks
We removed the cam and did not pay attention to timing marks. the engine was rotated without cam in it. How do we set the timing?
Take the cam out and put the piston at TDC
Look at the cam with the cam gear facing you.
Turn the cam until both lobes are down(on the bottom of the cam)
Look at the cam gear, there should be 2 marks across from each other at 3 o'clock and 9 o'clock
Those marks need to be parellel to the head when you set the cam in the head, carefully place the timing chain around the cam gear, trying not to move the cam.
Once you have the chain on, push the cam down in its slots in the head and look ate the timing marks on the cam gear.
They should be parellel with the head, and straight across from each other.
Recheck that the piston hasn't moved and your still on TDC.
If all is good put the rockers/valve cover on and timing chain tensioner in. Tighten the cover to specs then adjust your valve clearances to specs and your done with the timing.
Nov 29, 2010 | kawasaki KLX 125 Motorcycles
Blown head gasket
please read all before starting not to bad to change did you check compression if your sure that's what it is its about 4hr job.start by putting #1 tdc intake side.note where vacuum hoses are can mark with gray or yellow perm marker remove breather all plug wires exhaust manifold then intake manifold remember what bolts in and whats nutted on.remove break booster cross vacuum hose and egr control valve on left rear of intake side remove vale cover ((you'll have to get something to hold tension on timing chain so not to let tentioner come out inside timing chain cover when removing came gear)) remove head bolts only in off order so not to put tension in one area. do not remove cam shaft bolts and do not turn cam shaft at all after timing gear is removed take off head and check piston walls for wear replace gasket and put back in GOOD LUCK
Jun 30, 2010 | 1985 Nissan Pickup
How to change a timing chain on a fuel injected v8
Same as any other v-8 dis-assemble the front of the engine to get to the timing cover. Loosen the oil pan bolts to allow the timing cover to be slipped out. unbolt and remove the timing cover. Turn the engine over by hand until the dot on the crankshaft gear( the small one) is at the top 12 oclock position, and the dot on the cam gear(large gear) is at the bottom 6 oclock position remove the old cam gear and old chain. Install new gear and chain with the marks in the same places. Re assemble engine. DO NOT be tempted to just put in a new chain, replace the chain and cam gear as a set, wear on the cam gear will cause the chain to be slack, which in turn causes the cam timing to be late.
Mar 12, 2010 | 1992 Chevrolet C1500
Lotsof knocking no power
If the cam chain jumped then the tensioner is not tight. Timing is way off and valve hit piston. Need to **** case and replace tensioner, dry time then install new piston and pull vales to see if they are bent.
Sep 23, 2009 | 2000 Husqvarna TE 610
My 4.7 2002 dodge 1500 will not start
i purchased a new timing chain set and the cam pickup was bad on the new cam gear and we had a no start problem. i took the valve covers back off put the old gear on the cam and it started. BUT be careful if u do that you have to wedge the timing chains apart before you remove that gear so the hyd adjusters do not over expand. 4.7 dodge engines **** BIg they made them trying to save gas but the parts and repair over-ride any gas saving i got.
May 12, 2009 | 2000 Dodge Durango
Cam timing setup fro 1983 GPZ1100 Fuel Injection Model
Your timming marks on your cams are off. You got to go back inside your motor. Your ignition timming and your cams got to be timed the same.Are your cams turned the right way ? IS your timming chain set right? Is your cams turned backwards? I hope you did not ben no vales.
Mar 20, 2009 | kawasaki GPZ 1100 Motorcycles
How to set a timing chain on a 1992 dodge dakota 318
Usually there is a dot on the crank gear and one on the cam gear. Crank is up and cam is down but you still need to make sure you have TDC=top dead center
Mar 16, 2009 | 1992 Dodge Dakota
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
