Question about Emerson Televison & Video
Dvd wont stay in
When I insert a dvd it will pop right back out.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 113 Answers
Maybe you need to clean your dvd player. After some time they do accumulate dirt from other dvd's you watch on it. This should work, if not probably be cheaper to buy a new one.
Posted on Apr 17, 2014
TV/DVD COMBO DVD WILL NOT STAY IN
Are you inserting the disk the right way around?
Sep 03, 2014 | Sylvania Televison & Video
I inserted a DVD wrong side into NEC TV NLT-!9HDDDV3. How do I remove it?
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Mar 29, 2013 | Computers & Internet
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Brand new tv with built in DVD player when you insert a DVD, it just pops right back out and will not play the disc
Hello there,
I believe you need to switch the TV to the DVD input mode before inserting a disc. There should be a button on the remote or the TV labelled INPUT or SOURCE. Try pressing this repeatedly until "DVD" is shown on the screen or use the UP/DOWN arrows keys on the remote to select DVD from the input list, then press OK / SELECT / ENTER to choose DVD mode. You should then be able to insert a disc and play it.
I need to check some details for this TV and will get back to you shortly. If the TV really wont accept any disc, then you've bought a lemon and the TV needs to be returned to the store for replacement asap. I will post back with more details below in a few minutes.
Regards,
BElectric
Mar 08, 2011 | Sylvania LD190SS1 19 in LCD TV
CD will not load. It will insert spin and pop
hey
in this case you can do thing and check for the drivers
do right click on my computer icon and then got properties- hardware- device manager
then go in DVD and expand it and highlight each adaptor from there and uninsatll it , then do a right click on
DVD and the scan for hardware changes if that works than it good other you need to look for the drivers for your DVD rom
Dec 11, 2009 | Nintendo Wii Console
RIBBON WONT STAY DOWN WHEN YOU TYPE
Carrriage assembly could be broken, otherwise screw is popped out of gear in the right. With carriage all the way left, take out screw in the middle of white gear, pull out gear and pin, push down carriage top, insert pin in carriage and re-install screw.
Jul 02, 2009 | Brother GX-6750 Typewriter
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
May 29, 2009 | Dell Studio XPS 16 Notebook
Disk tray wont stay closed.
I am having the same problem with panasonic Karaoke player, it wont play anything cause the drawer wont stay closed!!! HELP!!!
May 05, 2009 | Televison & Video
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
