Question about Whirlpool Refrigerators
Beeping After a thunder & lightning storm our fridge frequently but randomly beeps when either freezer or fridge door is opened. 4/5 times it will beep straight away once door is opened. Foods are still being chilled as normal.
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 650 Answers
Thunder storms can cause control boards to go erratic. Try unplugging the refrigerator for a minute or two and after plugging it back in hopefully the problem will go away.
Posted on Apr 13, 2014
  • 400 Answers
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Posted on Mar 04, 2009
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
SOURCE: refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
Posted on Jul 30, 2009
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Posted on Feb 12, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
Why is it beeping?
if temperature is rising, you will get a beep. you need to find why the temp rising. Clean condenser coils and make sure that condenser motor is running art full speed.
Sep 01, 2015 | Samsung RS275AC Refrigerator
Zanussi zenb9950si
What is the beep for ? Temperature sensor ? Power sensor ? Door open sensor ?
Oct 30, 2013 | Zanussi & Electrolux Fridge Freezer Handle...
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Mar 04, 2009 | Refrigerators
Fidge beeps and warning door open comes on, temp fluctuates
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. YAY.
Jan 26, 2009 | Refrigerators
Refrigerators Logo
272 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
