I restart my modem an i want to get back wifi on it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Press the top button for 5 seconds it will the allow wifi to work again
Posted on Apr 13, 2014
How do i re-enable the wifi in my pc
You state that your wifi "router" will not connect to the internet. That is not inside your computer. The router is the cable modem or dsl modem that transmits the internet in your house. Depending on how it is setup, you may have a second device that separately sends a wireless signal out. The best thing to try first is to turn each device off for 10 seconds and then restart. Some modems have battery backups, so be sure to pull the battery if that is the case to ensure a complete power off. Then restart and see if you have your internet back. This fixes 75% of the issues in this situation.
Sep 23, 2014 | Samsung Computers & Internet
Wifi button don't works
Ok follow this steps to check the wifi driver go to my computer right click it now select properties now click on device manager check for the modems section try to see if u see ur wifi modem listed if u see a yellow icon on ur wifi driver it means u need to install the driver again if everything is ok right click the wifi driver and select uninstall driver then restart ur computer driver should automatically install tell me if this fixed ur problem
Sep 02, 2014 | Computers & Internet
Why has my tablet suddenly not receive my wifi connection; it says it is a poor connection. I have tried reconnecting it but to no avail. What else can I do? I do not believe it is the modem and the...
Hi Dolores,
You may want to try restarting your devices starting to modem ( unplug re-plug power cable for 2 minutes) then your tablet. After that try to re-connect to your wifi make sure you are not at least more than 300 ft away from modem though your tablet has a good wifi connection system already ( you should not getting this issue ). Hope it helps.
Apr 29, 2014 | Samsung Galaxy Tab 101 Tablet...
Motorola e365 schematics
Have you updated drivers for the modem or wifi on the system? Depends on the version of windows you have but if u go to search in the start panel and look for devices
and it should show a list of the hardware on your system. Your are looking for anything to do with your modem or the type of wifi connecter on your system. If you don't know do a quick searchon google and look up your pc type and the ask about the type of wifi to specific to your pc. Should give info and then you know what are looking for. Then click on the plus or drop down beside the name of the modem or wifi hardware and click it. A window will open up. Your are looking to the tab with update drivers. Do that and the save everything then restart pc and make sure your wifi is on and setup then try to connect. If that isn't working go to modem or router website and check for updates there specific to your op system and pc . Good luck hope works out.
Apr 15, 2014 | eMachines Computers & Internet
Won't sign onto wifi network
try reset the wifi device (modem or router)...then restart the chromebook....then try to sign in again...
Mar 02, 2014 | Samsung Chromebook Series 3
Netgear wifi router
1) does it lock up completely or will it work hard lined when wifi fails?
2) do all devices wireless fail or just a single device?
3) do you lose connection to the wireless completely or keep the connection but lose access to the internet? (confusing but very different to me)
in the end you could narrow down the problem but if you have already reset to factory defaults and set back up again and again then it may be time to retire that old router.
Dec 28, 2012 | NetGear DG834G Router
I have a dsl wifi, now i cant get any signal from my ipad2, i use to have no problem for three moths before.
Had same problem when I installed new dsl router/modem.Tap settings ,tap genaeral,bottom of page tap reset,then tap reset network settings.Ipad will reset network and restart.You will have to then go back to set up network again and reenter password if set.Worked for me.
Oct 22, 2012 | Apple iPad 2 Wifi 16GB
I cant get wifi and internet on my computer at the same time
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
Feb 28, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless light on modem is off and wireless service is out. Modem is a 2wire654
Unplug and plug back in the modem from power. If still not working. Restart pc. Or disabled and then enable the wifi network.
May 03, 2011 | AT&T Computers & Internet
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
