Question about Sub-Zero 690 Side by Side Refrigerator
8 year old Sub-Zero model 690. Condensor coil leaking
8 year old model 690. Repairman says the copper & aluminum condensor is leaking. Replacement is all aluminum. Is there a historical problem with mixed metal condensors that Sub-Zero has fixed?
  • 82 Answers
When copper and aluminum are connected it cannot be welded, it has to be crimped. this is a problem that is not exclusive to sub zero, an all aluminum evaporator ( if it is in the refrigerator it's an evaporator) should resolve the problem nicely
Posted on Jun 18, 2009
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
replacing Evaporator coils on Sub Zero.
Posted on Jun 27, 2015
I have a 690?s sub zero and the vacum condensor is flashing, I did that a week ago and now it's bck on. Any suggestions?
when i see this and it's not the coil needs cleaning it's usually a leak in the evap coil.the freon is leaking out.have you noticed any ice on the left hand side of the back wall around two feet up from the bottom glass shelf and the fridge getting warmer?the sealed system is under warrany for 12 years,if it isn't under warrany the whole job is close to 1000 dollars,if it is under warrany you'll save around 250 dollars and this isn't something you can do.good luck with your machine.
Apr 19, 2011 | Sub-Zero Refrigerators
I have a subzero 690...the freezer side is only cooling down to 50 degrees but refridgerator is working fine....control panel says to vacuum condensor. I vacuumed and also used compressed air. This made...
i would call a tech in for this,sub zeros are not like regular machines,the freezer and fridge have their own components,it's like two machines in one,whenever i've seen the vac condenser it's ussually a freon leak in the fridge evap coil so i would have to think you could have a freon leak in the freezer section,usually the bottom copper loop rots out,your talking about a machine that costs almost 10,000 dollars or more,if it is a leak i think you're covered for the first 12 years on the sealed system,you can do a few checks,look at the door gasket,does it have any rips or does it look damaged in any way,also i've seen the light switch stick and the lights stay on when the door is closed and heats up the freezer,open the freezer door and push the door switches in and out and see if the lights go out,but other than that i would call a tech in to repair your sub zero,i know if you do have a leak in the system it's could be close to a grand or more to repair and you need all the tools to do the repair.
Apr 02, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
I have a ten yr. old Sub Zero model 642. The
maybe a re-gas will last another ten years...if the leak is that small a re-gas will probably last it days out....ask the service man to re-gas it so the food does not spoil until you can save up for replacement...then just see how it goes.
Jul 21, 2010 | Sub-Zero 690 Side by Side Refrigerator
I have a 7 year old sub zero 632. The
The sub zeros I have worked on have a compressor for each side. Is your fan blowing. You may have a defrost timer or heater. Possible low on gas but thats not very likely the sub zeros are made very well. Check to see if fan is blowing. Check condensor coils on top to see if they are clean. Check to see if your condensor fan is blowing. These are just possoble problem you can check if every thing looks good. Call a service tech ask for free estimate on repairs. Rus
Jul 06, 2009 | Sub-Zero 632 / S
Sub zero 690
Call the factory at 800-222-7820.They will give you a list of the authorized servicers in your area. It sounds like the evaporator and the parts will be covered by the year 6 through 12 parts only warranty. If you are in Westchester County $625 sounds right. The vacuum condensor flashes when the compressor has too long of a run time and will reaapear a day or so after it has been reset. I assume the tech made sure the condensor fan was running and the condensr is actually clean.
Nov 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero Fridge not cooling and ice forming
You do have a leak and it will be in the evaporator. So call a factory authorized company and have it replaced.The warranty of a Sub Zero sealed system is full parts and labor for years 1-5 and parts only in year 6-12. Sub Zero expects a lot of their service companies so it behooves you to call one. To find an authorized company go to http://www.subzero.com/locator/locator.aspx?type=0&zip= or call 800-222-7820
May 31, 2008 | Sub-Zero 601R
690 SubZero Side-by-Side Fridge
You need to reset the controller open the door and press and hold the "Bell" looking symbol for 15secs then release it should go away let me know if that worked
Jan 26, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
799 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
