Question about Parrot AR.Drone 2.0
Control link missing
Brand new - can't get it it to fly. The lights are red (battery at 35%): control link missing or Emergency smth messages show up. What do I need to do???
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Remote control not working brand new sony rm-lj301 remote
Check the remote control for its infra-red emission. Even new pieces might have the fault. You can check its infra-red emission, by a mobile phone having camera option. If you wish to get more details about how to check a remote control, check this link.http://electronicshelponline.blogspot.com/ If the remote control emits infra-red emission, and still TV do not respond to it, the fault will be due to a damaged infrared sensor inside TV. This part can be located just behind the infrared window at the front panel of the TV set. You have to open the TV, to access it and to replace with a new one. The part will look somewhat like these.
Jun 11, 2013 | Televison & Video
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
Remote not working
I have rebooted several times during the reinstallation of the software. I also tried different USB, but no luck! Could it be something with the USB driver anyway? The system says the drivers are ok though.. Does anybody know the life expectancy of the batteries to this remote? I don't think it is the batteries though, because the red light on the remote is bright.
Nov 12, 2012 | Sony Nsgmr1 Remote Control
Touran 2004 TDi Fuse layout
Here it is:
The fuse box diagram for 2005 VW Touran
Fuse box / relay plate, fascia 1:
1. F1 (5A) = Interior rear view mirror
2. F2 (5A) = Trailer socket
3. F3 (5A) = Heater / Air Conditioning (A/C)
4. F4 (5A) = Fuel lift pump control module
5. F5 (5A) = Heated front seats
6. F6 -
7. F7 (5A) = Heated front seats, heater / Air Conditioning (A/C)
8. F8 (5A) = Heated windscreen washers jets
9. F9 (5A) = Airbag
10. F10 (5A) = Telephone
11. F11 (10A) = Power steering
12. F12 (5A) = Automatic transmission (AT)
13. F13 (10A) = Headlamp adjustment
14. F14 (10A) = Anti-lock brake system (ABS)
15. F15 (5A) = Data link connector (DLC), reversing lamps
16. F16 (5A) = Databus cooection
17. F17 -
18. F80 (5A) = Emergency vehicles
19. F19 (5A) = Emergency vehicles
20. F20 (10A) = Parking aid control module
21. F21 (5A) = Automatic transmission (AT)
22. F22 (5A) = Auxiliary heater
23. F23 (10A) = Stop lamps
24. F24 (10A) = Auxiliary heater, Data link connector (DLC), heater / Air Conditioning (A/C), light switch
25. F25 -
26. F26 (10A) = Engine management
27. F27 -
28. F28 (5A) = Light switch
29. F29 (15A) = Rear screen wiper motor
30. F30 -
31. F31 (15A) = Auxiliary heater
32. F32 (15A) = Windscreen washers
33. F33 (10A) = Emergency vehicles
34. F34 -
35. F35 (10A/40A) = Heater / Air Conditioning (A/C)
36. F36 (10A) = Emergency vehicles
37. F37 -
38. F38 -
39. F39 -
40. F40 (20A) = Trailer socket
41. F41 (20A) = Trailer socket
42. F42 (15A) = Auxiliary power socket
43. F43 (15A) -
44. F44 (5A) = Alarm system
45. F45 (5A) = Audio system
46. F46 (5A) = Multifunction control module 1
47. F47 (25A) = Cigarette lighter
48. F48 (20A) = Headlamp wash / wipe system
49. F49 (10A) = Door function control module driver + passenger
50. F50 (30A) = Heated front seats
51. F51 (20A) = Sunroof
52. F52 (25A) = Multifunction control module 1, auxiliary heater
53. F53 (25A) = Multifunction control module 2
54. F54 (5A) = Automatic transmission (AT)
55. F55 (5A) = Emergency vehicles
56. F56 (15A/40A) = Heater / Air Conditioning (A/C)
57. F57 (30A) = Door function control module driver + passenger
58. F58 (30A) = Door function control module left + right rear
Audi Performance Chip
Aug 23, 2012 | Toys
Hyundai dvd model hy-03s remote not functioning
first thing is the obvious, make sure you have brand new batteries installed. If you have a camcorder or digital camera, point it at the remote control and push record, while recording, press some of the buttons on the remote. the camera will record the red light if the remote is working (camcorders and digital cameras can see this light even though people can't) to do this with your digital camera, have somene push and hold one of the remote control buttons while you take a photo, the red ligth should show up in the photo. If you see no red light then you have a bad remote control and will need to send for one or get one ordered through the store, one other option is to buy a universal remote control and try getting that to work, good luck
Mar 16, 2011 | Hyundai Televison & Video
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
I bought on of those falcon-x helicopters for my son and just wanted to know how to charge the battery as efficiently as possible. The helicopter needs to be off correct? And how long should it charge for...
The instructions say the helicopter is ready to fly when the led shows red. I found some info online that says to charge the helo for 35 minutes. I've been letting it go 45 mnutes, and have been getting abou6 6 minute flight times. Unfortunately, my helo will no longer fly forward or backward. Does anyone know how to adjust the control for the tail rotor?
Dec 25, 2010 | Toys
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Parrot AR.Drone 2.0 Logo
20 people viewed this question
Top Parrot Cell Phones Experts
Andrew Wright
ray gallant
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
