Question about Kenmore 23822 Top Load Washer
Won't fill with water...just hums...will spin and drain...won't rinse and spin...water enters tub only at point for detergent dispenser
Check wash/rinse settings inlet water valve
Posted on Jun 18, 2009
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
Seems like there should be a pump or sending unit the would be controlled by the cycle timer. ProbAbly went bad. Hopefully you got the extended warranty?
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Tub leaks, with a partially filled tub (2.5 inches measured from the lowest point over the pump assembly.) Promblem occured after the washer was idle for 3 weeks. Have just replaced the main water inlet...
I am assuming leaking when it is running, not sitting idle. Leaking from the door? Fill and run unit for 1 minute with no detergent. Open door. Are suds present? Suds turn into water when they drop to the floor. Suds can flow over the lip of the tub and drip to the floor. Oversudsing, Sometimes old detergent breakdown. Rinse aid dispenser leaking will cause oversudsing. Combination of all in one products will cause many problems. If suds are present after running unit a minute, pour a cup of cooking oil in unit. Run and fill it a few times until suds are gone. Possible most common cause is dispenser latch grommet.
Oct 15, 2010 | Maytag MDB7100AWB Dishwasher
I accidently put Jet Dry DISHWASHER CLEANER in my rinse agent dispenser and I need to know how to drain it out..help!
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 17, 2009 | Washing Machines
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine doesn't dispense detergent
Here's a few suggestions you can try. First, open the dispenser tray far enough to where you can see inside. Enter diagnostics mode by selecting DRAIN SPIN, NO SPIN and pushing ANY button under OPTIONS 4 times (it has to be the SAME button, though). This will enter the washer into diagnostics mode which checks the hot and cold water fill functions, the dispenser tray functions, tumble, spin and drain. Watch inside the dispenser tray to see if you can see any water flushing through the various compartments (detergent, bleach, fabric softener). The water should be fairly steady and forceful. There's not much else, besides gravity, that forces the detergent into the wash tub. Now...if you don't see the desired water flushing action that you should see, check the overhead portion of the dispenser cavity. Pull the tray all the way out for this. There are a series of holes where the water is forced through. Sometimes these holes become clogged and will not allow enough water in during the fill and rinse cycles. It's usually the fabric softener side that becomes blocked, though. You can take some cotton cotton swabs and perform the tedious task of cleaning each hole if they are blocked. I've had to do this before and it does fix the problem. The other possiblities are the fill valve not allowing enough water pressure through (but, you didn't mention anything about a slow fill problem), or a kinked or blocked hose coming from the fill valve. If you wish to check the fill valve, turn the water off and remove the hoses from the back of the washer. Check the inlet screens for clogs. If you have hard water, well water, or BOTH, it is common for the inlet screens to get accumulated with sediment. Again, some cotton swabs will clean the majority of the sediment from the screens (you can use a little white vinegar as well). If you wish to check the inlet hoses from the fill valve, remove the top of the washer by removing the three torx screws along the back of the washer. The top will slide back then lift off. There are a series of hoses from the fill valve to the dispenser. Check to see if any of them have become kinked. I hope this information is helpful to you. Post back with comments if you need further assistance.
Jan 29, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 23822 Top Load Washer Logo
141 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
