Question about Radio Shack Pro-2055 Base Scanner
Replacement antenna for pro-2055
Replacement antenna
2 Suggested Answers
One Wire
  • 126 Answers
SOURCE: all channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Posted on Jan 28, 2008
Unlock my scanner radio shack PRO 2055
Hi,my name is John. Welcome to FixYa. Hold down the L/O button until you hear it beep twice, then all channels are restored. good luck and thanks for choosing FixYa. John
Oct 27, 2010 | Radio Shack Pro-2055 Base Scanner
GOT NO MANUEL FOR THE UNIDEN PRO 2055. WOULD LIKE TO PROGRAM NEW FREQUENCIES INTO THE SCANNER..
You can download and print an easy to read aftermarket manual for your scanner here:
http://www.marksscanners.com/97/97.shtml#receive_modes
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Sep 11, 2010 | Radio Shack Pro-2055 Base Scanner
Is the pro 2055 digital ?
The PRO-2055 is a versatile conventional/trunking scanner, but it does not have the capability to monitor APCO-25 digital transmissions. For an operating manual that is "Easier To Read" than the factory operating instructions, follow this link:
http://marksscanners.com/97/97.shtml#receive_modes
Bill B
Sep 09, 2010 | Radio Shack Pro-2055 Base Scanner
How do I get the pro-2055 scanner to only hear the Trunking channels I want and by-pass the agencies I don't want to hear. I've programed the talk groups in but can't get it into an ID scan mode.
Hi, my name is John. Just L/O the ones you don't want, then SCAN..hope this was helpful Please rats this solution on the thumbs four thanks John
Sep 04, 2010 | Radio Shack Pro-2055 Base Scanner
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Will the Pro-2055 pick up the new digital systems used in Indiana called SAFE-T?
Sorry, but the PRO-2055 is not capable of monitoring any digital transmissions.
Dec 27, 2009 | Radio Shack Pro-2055 Base Scanner
I need to know how to program this scanner. Radio shack pro-2055
The programming instructions are too detailed and lengthy to post here, so here's a link to the manual for your scanner. It will walk you through the programming process.
For an extensive database of active frequencies and systems in your area visit
or
www.CityFreq.com
If this response helps, please take a moment to post a rating. "Very Helpful" would be appreciated.
Dec 04, 2009 | Radio Shack Pro-2055 Base Scanner
Pro-2055 size
Dimensions (LWH): 7.2x5.3x2.2" (18.29x13.46x5.59cm)
http://wiki.radioreference.com/index.php/Pro-2055#Specifications
Jun 18, 2009 | Radio Shack Pro-2055 Base Scanner
Programing pager tone alerts
The scanner itself does not directly support decoding of pager tones, but if you know someone who can manage their way around a bit of soldering and hacking, they might be able to rig something up with an old pager which could be triggered from the audio output jack from the scanner.
May 15, 2008 | Radio Shack Pro-2055 Base Scanner
Radio shack pro 2055
Hi, My first guess with the limited info is, either you have the attenuator turned(which is like an RFgain), or you have a defect in the antenna or coax(if it's mobile.) For the attenuator see pg.66 of your manual.
I assume it's picking up your ham radio when you key it, but at close range it'll pick it up without an antenna.
I hope this helps you sort it out,, Mechanic
Dec 01, 2007 | Radio Shack Pro-2055 Base Scanner
Radio Shack Pro-2055 Base Scanner Logo
27 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
